GRABPay MasterCard
Trazora
Hi all, dont forget to top up your Grab wallet using SCB BonusSaver and/or Manhattan cards. I top up till it is more than 3k to get 3% for Manhattan card.
The door will be closed on on 2/5/2020. :(
Door already closed. Will not post by 1 may cos public holiday. 2 may already excluded.
Trazora
any where shows the consolidated list of exclusion merchants?
If you mean exclusion from grab rewards https://help.grab.com/passenger/en-sg/360038831171-What-are-the-transactions-that-DO-NOT-qualify-for-GrabRewards-points
Imhthc
anyone know why sometime unable to top up grab pay using credit or debit card? Intermittent issue though.
The only few times I encounter failures in top-up were due to weak wifi signal or wifi handover to 4G during my top-up txn. I would point the issue to connection and not the app for my cases.
saintgtril
Hi rouletteking, i did encounter the same issue. What i did is to save the credit card in the Grab apps, then the issue is resolved. Try it and let us know if it works for you. :D
slowpokie
Is there any card can clock for card rewards regardless of the farming teir??
Now all cards basically cant farm super sian
Imhthc
Hi Trazora, heng, all my SCB manhattan transactions are posted on 30/4/2020. How about yours? :)
If I remember correctly there is a cut off time. Like before 12nn or 2pm, it is posted on the same day, otherwise it is posted one day later. I got to know it when I was chionging for the scb card rebates on grab last time?
saintgtril
All my Grab top up transactions on 30/4/2020 are posted the very next day. Even transaction as late as 7pm plus on 30/4/2020. Heng ah!
kashanai
Doesn’t seems like have due to some error
The cash back cards seems to put grab top up until 0% 6 months installment plan. Thus , not applicable for cashback
amex true cashback still have rebate for grab topup, other amex cards exclude grab topup
IcYFl4mEz
That should be the technical error right? They will solve it
