Redmi 8
kinderbuenojhj
Anyone knows whats the pricing nao for Redmi 8 Global Version 3 + 32GB export set ?
8-lane
8-lane
Geng Shuang
Any idea what settings to tweak if I keep hearing my own echo while talking to others over the phone?
clleong
Whatsapp issue
My note 8 not showing (whatspp) incoming call notification, until the other party hang up, then i will receive a missed call notification. Any help to solve this issue is appreciated. Thanks
Teo Ming Ern
Try updating your phone? Or check the notification section... did you allow notification for Whatsapp? There are two places to look at... the general notification part and the app itself...
cenatorrie
Hi All
would like to check if you encounter any heating issues? the phone will heated and drain the battery even if you not using it? because i encountered it and not sure what to do even though i have closed and shut down most of the apps.
PeasantBeing
Hi All
Back up all your data and do factory reset.
If problem persists, bring to service centre.
Sent from HUAWEI EVA-L19 using GAGT
decibels
bought 2 weeks ago and my phone kept having no reception/network.
Both my tpg and vivifi cannot call out or received call occasionally. Pull out the sim tray and put in again also same problem
orwell76
The APN of your redmi 8 must be set to TPG
For voice call must key in this code to enable
carboy00
Update to the latest version and see if it solves your problem.
K202020K
Don't think the latest Android security patch could solve a fundamental, critical issue such as network connectivity issues.
Sigh ....
From Redmi 1 up till now the Redmi 8, yet still have so much user complaints.
No wonder can only give one year local warranty when others are having two years.
Yet the device is no longer attractively priced against the competition.
Have been wanting to order a Xiaomi phone for a long, long time .... but the users here are giving me second thoughts about it. Sigh .....
hkchew03
Sigh ....
Which manufacture have 2 years warranty? on their budget series? Last i rmb is only Huawei due to getting confidence from buyer over the ban issue
hkchew03
Try ensure "autostart" is on for all the messaging apps or anything with important notification.
carboy00
Sigh ....
Undoubtedly some may have faulty units. My mum's Redmi 8 has both SingTel prepaid and TPG SIM in it, no major network issues. The Redmi 6A before that had the same two SIMs in with no issue too. I have been using Xiaomi since 2014, Redmi Note 4G, Mi 5, Mi A2 and now my Pocophone F1 and Redmi Note 8 Pro. No major issues with all, closest was diagnosed motherboard issue with my OOW Mi 5, other than that mostly just software bugs that were later fixed with updates. I do agree that the prices are no longer as competitive especially the physical stores, better luck with online stores.
