*adiBOY
- Mar 5, 2008
The new updated MacBook Pro 13” 2020 with scissor switch is out!
https://www.apple.com/macbook-pro-13/
2.0GHz version is Intel 10th Gen~
while base model is 8th Gen~
https://www.apple.com/sg/shop/buy-mac/macbook-pro/13-inch
Limit 5 per customer.
interesting. now is the wait for 10th Gen for 16"~
It is cheaper than before with upgraded spec.
Base model with two ports all get cheaper. Same price you can double storage than before.
4 ports model you get double storage and double ram than befor.
Faster RAM and storage too.
Where is the 14”?
But this time round the mbp quite cheap lay.
When I bought my tb 2016 13”, spent over 3k plus for 16gb n 512ssd.
It's cheaper now cos Apple is preparing for new design with Mini LED later this year.
14" and 16" and and 12" with ARM chip next year.
its cheaper because apple has finally decided to double the storage and ram. thats it. you are paying $600 less than before. it was quite ridiculous that some 4tb port models in 2016- 2018 started at 128gb and costs $300 to upgrade to 256 and another 300 for 512. Ram is also $300 more for 8 - 16gb upgrade. If you checked the 2019 13 inch macbook pros. it costs 3.2k to get 512gb ssd and 16gb ram. now the same variant is 2699 sgd.
