I received my S7 today. Spent quite some time getting it out of the box. Will post impressions later.
Not bad. I've a few slipped discs at around L4 to S1, 1 is sciatica. My left thigh will hurt if I sit for long or badly. So far I don't feel any aches, so that's a good sign.What do you think of the Artificum?
Ok. Time for first impression. Do note when i use HM Aeron as reference it's based on my experience with the old version (not remastered) which i last touched 4 years ago. So it's loosely based on my fading memory.
So let's get to the important part.
Out of the box:
- The chair looks good just like in the product pics.
- Hard casters work really nice and smooth on my homogeneous tiles.
- There were some brown dust on some parts of the frame which i felt they should have at least cleaned up after assembling in factory. Dust got swept away pretty easily but already gave me some negative feeling of what was about to come.
- What made it worse was while pushing the chair to my room, i noticed the back and arm rest unit wobbles easily leading me to suspect that they did not assemble properly.
- By now the excitement of exploring my new "toy" has worn off and turned into "Ok let's see how much worse this can be."
Quality:
- The materials used seems good.
- The quality/type of the plastic frame shell and adjustment levers reminds me of Aeron.
- Arm rest pad is some kind of good rubbery plastic which is less warm than leather and won't absorb sweat.
- Mesh material has more fabric cotton feel and gentle on bare skin. Like previous poster i recall old Aeron's mesh more plasticky feel.
Comfort:
- Seems to be very customizable. Notable adjustments are seat depth, lumber height, arm rest 3D movement just like old Aeron. However, additional functions like back rest tilt tension, and the side tilt are bonuses over old Aeron. I have always found chairs with loose back seat tilt to be annoying and usually set them to no tilt. But since i can adjust the tension on S7, it sort of behaves like a very firm suspension and cushions my back when i lean back after losing a game.
- Lumber support. On old Aeron, the lumbar support facing the mesh side is hard plastic. On S7, this part is soft firm rubber plastic. Kind of like those plastic insulation curtain sheets found in cold kitchens. Might be softer on the feel for those who prefer. Would have been nice if depth can be adjusted for this.
- Side tilt. This came as a surprise. Side tilt allows more freedom in movement while still offering support to your posture. If you're in lazy mood and just want to sit back and watch a movie or game, you are still able to stretch your waist and tilt a little to the sides while the rest of your body rest lazily on the head rest and arm rest. This is a plus for me as i can see myself needing much less times to stand up and stretch my upper body. I do wish that they could add tension adjustment for this and also a toggle to on/off.
- Seat front tilt. This function seems to work well in conjunction with back rest tilt. When leaning back, the seat front tilt allows your hip and butt to straighten approx. 35-45 degrees forward so that your body can lay more straight. I have no need for this function but think it'll benefit those who likes to laze and sleep on the chair. Oh also if you like to piak piak on chairs this function will benefit you.
- Head rest. Nothing much to comment on this. You can adjust the height by pulling/pushing it up/down. The adjustment is pretty stiff and takes many tries to get it at my desired height. Would have been nice if the "teeth" is smoother and easier to maneuver and perhaps add a depth adjustment and lock. But if this is included without extra charge then no complains i'll live with it.
- Arm rest. Just like old Aeron this has the "3D" adjustment of height, angle, and depth. But also like old Aeron the angle and depth can't be locked which used to annoy me as i like to pull the chair towards me from the arm rest and this action accidentally move the angle and depth which i have to re-adjust after sitting down. That said, this isn't a big issue and may not affect other users.
Ok. The time it took me to think and write this out while sitting on the chair. A summary of my first impression for today is the quality and basic function of this chair and the posture support if offers definitely hits around 3/4 of it's price. There are certain areas highlighted (above) that i wish was improved on or added but that may also mean increased prices which i may not appreciate.
The bells and whistles like the side tilt has bigger potential to hit way more than the remaining 1/4 of it's price. So all in all i'm very happy with the S7 now and it meets my expectations and only time will tell if it can exceed more.
I slouch a lot and if i tilt all the way, the Aeron will have a gap behind.
i think im not going ahead of the atlas headrest MO since the saving is not that much.
i will still be buying 1 for myself and anyone interest you can use the $5 discount code - CISA6
Not sure which part of the chair you want to see but here's a few photos.
Out of the box:
Quality:
Comfort:
Looks good.. But very plastic leh.. Really is one cent one quality.. Cant fight Herman Miller aeron qualityNot sure which part of the chair you want to see but here's a few photos.
Thanks for the pic!Looks good.. But very plastic leh.. Really is one cent one quality.. Cant fight Herman Miller aeron quality
HM aeron remastered is all using plastic now. even the base is plastic too
Ya. Aeron is also plastic. Unless you are referring to the chrome series or something which I think cost more.
I am absolutely happy with my Aeron chair as well! arrived yesterday too! It is definitely metal for the frame of the chair
