U click activate before u make the changes or after? If u did it before, u need do it after u made the changes
Also when u reboot, is it because u r doing firmware upgrade to 10.5.8? That firmware will reset the volte settings
Anyone feel that after 10.5.8 update their touch response feels snappier?
Sent from OnePlus 8 Pro using GAGT
as mentioned do escalate the issue through the google pay support at least they are aware and work with TransLink or oneplus devMy SG Google pay doesn't work on transportation too. It just scan and says "phone move too fast". I have disabled the original pre-installed Google pay.
Sent from OnePlus IN2023 using GAGT
Hmm... Am on OP6 actually. Did get a firmware upgrade but that was a while ago. And ya also clicked the Activate after changing the Sub0 from Overseas to India. Just to confirm, I can leave Sub1 as Overseas?
I was complaining about touch latency few pages back. Hopefully this also fixes the scrolling weird behaviour
Posted from PCWX using SM-G986N
Which sim card slot are u activating volte on? Sim card slot 1 is sub 0, slot 2 is sub 1
Then deactivate oversea on sub 0, and setselected config for india vodafone on sub 0, then click activateAm trying to activate Sim1, hence Sub0.
Want to leave Sim2/Sub1 unchanged.
Gotten my OP8 for a week, G Pay doesn't work on public transport too. Called up transitlink and they said its OP's problem as older OP devices are tested and verified to work on public transport. New OP phones shouldn't have any problems too.
According to them, all Google-verified, NFC-enabled Android phones are able to work on public transport.
Yup, that's what I did.
Am I supposed to see some reaction on the phone screen side?
Or after clicking Activate on the PDC app, nothing on phone side, just reboot thereafter?
I have raise a support ticket to OP as well. Let see how it turns out.Sigh this is bad news man. Think gonna be some time before it'll be fixed on OnePlus. Lucky my work phone is Apple I can still use Apple Pay for that.
Nth will happen on phone side other then turning on volte toggle and see the volte icon appear.
I cant advise much alrdy as i nv see how u do for your phone. Just need to ensure follow all the steps in my guide can le
Will investigate a bit.
Thanks a lot for your help anyway!
