Plutonian
- Oct 30, 2004
Seems from the reviews there is latency issue wo
So sad..... but if anc is good. Dun mind also. Haha
Hi Soundpeats Truedots users.
I just wanted to check if yours automatically disconnect once you return the buds to the charging case? i noticed mine doesn't disconnect and I have to manually disconnect it from my phone.
Finally arrived after 16days. Good to see an english manual & instructions guide. Hope not too difficult to learn which side is for which function.
Ok since no one replied on the Fiil T1X, I played around with it. After you disconnect BT, the blue lights will still flash for about 2mins then will stop so I guess it turns off by itself.When I turn on BT again & try connecting the buds,it cannot connect.Tried putting the buds back into the case then remove after a few secs & can see both blue lights flash.When BT turned on again,can reconnect & now I can use the Fiil app to check battery % for each bud & can use the EQ settings so I guess there's no way to turn off the buds manually & you have to wake it up by putting the buds back into the case then will be able to pair with BT again.
Yes you can turn off. When the light is flashing blue just using a bit of pressure and press and hold both bugs at the same times with your thumbs till you see red like light and then release and the bugs will be off.
In the process if you see the bugs blue lights flashes or blue / red light flashes ignore those and carry on pressing (cannot release) till you see red light then you can release and the bugs will be off
Anything under $100 better than fiil T1X to recommend?
Anyone got the nuraloops here?
Thanks for the reply but put pressure on which part of the bud to turn it off? Then next time I need to use, how to turn the buds on?
The part where normally you will tap to control the bugs
To turn the bugs on just press and hold the same part and release when you see blue lights
guys, what would you recommend to upgrade from creative outlier air?
