Redmi Note 8
bbcccc
Thanks ! Would like to ask if vidmate, when downloading the video, heat up the phone ? I used a app called Tubemate and it tends to heat up.
Thanks.
no issue for vidmate so far
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
Pocoyoz
G90T same as 835 > 720G/730G :o
Squaredot
Is not hardware problem. Is Miui 11 issue. Should have been fixed in version 11.0.8.
Note 4x also has this issue with few version of Miui.
Is version 11.0.8 up?
mine shows 11.0.6.
didn't notice batt draining issue tho
Plastick
Anyone facing wifi being 'disconnected' out of sudden and the connected wifi network status written as "DISABLED". have tried connecting to mobile hotspot on the same instance but no issue. the temporary fix is restarting hp.
redmi note 8.
sian, till now my mum's set still facing such problem despite resetting modem. it's as though wifi has went to sleep.
the whatsapp also go to sleep after some time. even when make a whatsapp call to the phone also cannot wake it up. have to go in whatsapp to receive all the msges/missed calls. everything related to sleep, battery optimisation, background data settings also already touched on but still same.
ZhuTou!
Last solution u can go developer option to disable miui optimization
hellrace
Hi, am facing some issues with my Note 8 Pro. Tried to do a search but didn't find any info.
I got my set from Carousell from a local reseller, according to the seller, its a local set.
However, my sim card tray is really weird, its single sim card + TF card. Can't fit a second sim card at all. Apparently, i thought it should come with a hybrid for second sim or TF card. Anyone facing the same issue?
stylechap
Memory card is placed horizontal, sim card is vertical
PeasantBeing
Got try factory reset and do fresh install of apps? If you had restored from older phone, may face problems.
Sent from REDMI NOTE 8 Neptune Blue using GAGT
m/mink
sim card in slot 2 is placed like that.
hellrace
Same as what i found on youtube as well... really weird... wonder what the heck sim card tray i have in the phone.
Did a product authentication though and weirdly, it is indeed a local set.
m/mink
Any chance yours like that?
This is Note 8 pro too..
dedicated slots for 2 sim cards + 1 memory card.
hellrace
I saw this when i was searching online as well. This seems to be a set for the Indian market. Unfortunately mine only has 1 sim tray...
