jq75
- Dec 5, 2000
Updated on XS Max. Face ID now much ‘faster’ unlock process with mask on lol
Need to scan face with mask on again ?
sagu suggest the only way now is to do the face mask passcode unlock workaround which works about 75% of the time with face mask on, exposing 3/4 of the nose bridge
#saguwisdom![]()
Hmm, after keying in my Passcode a few times with the mask on, now my phone unlocks with my mask on. Did this happen to anyone?
Yeah, happened to me some 2 weeks ago and I’ve been able to unlock via FaceID with my mask on since. Quite cool actually haha.
Is IOS 13.5 really worth to upgrade to?
Anyone feels battery drain faster than 13.4.1??
Yup.........it went from 83 to 72 when idling I have nothing running on my background
did u check batt stats? if something is draining it will b logged there. anyway as mentioned many times already, after iOS update there will b background tasks so draining is normal
Hope the TraceTogether app will support the Exposure Notification API in the next few days or weeks as an update since 13.5 is publicly available now.
Well on ios 13.4.1 or earlier there is same issue no? Its not like in older versions of ios it can run in background but not 13.5.
Ah. Well yeah unless u dont mind your battery draining like crap. Good idea sh*tty implementation.he means update e app to use e n Google APIs. that will allow e app to work in e background. e app in its current state is useless.
And the 13.5 jail break is out.
How much drains are you referring to? Bluetooth should be fine, since no GPS is involved.
Its not just about bluetooth. Many ppl wrongly assume Trace Together runs in the background like most apps. It doesn’t. To work Trace Together must always be on ie the screen must be there all the time.How much drains are you referring to? Bluetooth should be fine, since no GPS is involved.
