Xiaomi Redmi Note 5
skai_11
I assume redmi note 5a pro is using the same battery...
Anyone knows how much to replace the battery? Suddenly lost charge and deplete to 0% within mins after 100% charged.
Or you guys would recommend to buy new phone instead? This phone is for my mum. Simple play games watch videos usage. Any recommendations what model under $100 or $150 is a good buy?
Thank you!
davidwong
Nowadays a decently entry about 180-250. If fixing is like 60 bucks should still worth fixing but if it’s 80-100 then is not worth (imo)
Thank you!
Kiwi8
Deluxe Member
Thank you!
Are u able to fix the battery by yourself watching the YouTube DIY videos? It is not very hard.
If so, then replacing the battery is very cheap, it is just $10 to $15 (including tools to pry open the casing). I checked Shopee.
By the way, in case u are buying a new phone and not using this phone anymore, then I would like to request you to give me the phone as I still have use for such a phone. :o
carboy00
Thank you!
https://www.mistermobile.com.sg/product/xiaomi-redmi-note-5a-battery-replacement/
Changed a few phones batteries here, not bad. Reasonable price.
yusoffb01
Thank you!
battery costs less than 20 and you just need to remove back cover held by clips
skai_11
Nowadays a decently entry about 180-250. If fixing is like 60 bucks should still worth fixing but if it*********s 80-100 then is not worth (imo)
Thank you. I also think so.
:o
Thank you. I'll try replacing the battery first :)
https://www.mistermobile.com.sg/prod...y-replacement/
OMG thank you so much for the link. At least now i know the prices if i go to shop and let them replace instead
Thank you. I saw the DIY but scared ownself not skillful enough.
GoodBetterBest
Got an old RMN5. The power button not working. Is there anyway to do self-repair ? Or can cleaning the button ?
Kiwi8
Deluxe Member
Can describe the problem in detail? Is it that the button doesn't pop back up? Or is really press liao no response?
GoodBetterBest
U can buy the silicone button pop-up replacement and replace it, see if it solves the problem.
You mean this ?
How solve power button problem ?
yusoffb01
lol . most likely switch issue. next time use tap to wake, auto switch on. even without power button can still use phone
Alternatively when u plug in to charger it will try to power on. if you hold volume down it will go fastboot mode.
download adb files, plug the phone to pc and type
fastboot reboot
It will boot normally
FinchGuy
Noob here. Any way to uninstall bloatware and download or transfer apps to SD card? TIA
