gregory_choo
- Nov 7, 2007
Some of them are literal bricks, won't boot, boot loop, etc, that's why need to use the hard method. Burning tool would work but I don't have a A to A cable, the 3 I have at home are all USB 3.0 cables and they don't work. I have done it before using a 2.0 cable but I can't find it. I have solved those that are bootable, delete everything, update latest play services downloaded from apk pure, magisk, overclock and kept them running at 1.5ghz so they won't choke on 1080p videos on vanced.
the cable is only $1+
https://shopee.sg/USB-3-0-A-Male-to-A-Male-Extension-Cable-Blue-Black-6-Feet-i.104590058.1848970843
for those boxes with only 1GB RAM, the most important thing to do is to remove google playstore and google playservices.
