iPhone 11/11 Pro
endlssorrow
can check, if wan to open the phone, only way is to press the right button ah?
the touch screen touch anywhere wont activate right?
*adiBOY
quick question: see that there is no way to add back the battery sign of how much percent left right?
only way is to connect a Bluetooth earpiece and then it will be there forever is it?
What do you mean? iPhone battery percentage will be shown once you swipe the control centre down from top right.
Other connected devices will be shown in the batteries widget.
endlssorrow
I mean for past older models, the percen is on the screen itself besides the battery icon bar. :D
but now die die must swipe the control centre down to view it right? :s13:
endlssorrow
Any way to stop the screen from “light on” when I flip flop or turn turn the phone siaz ?
endlssorrow
y sometimes I press the right button to close the screen but it didn't work siaz? lag?
endlssorrow
Are you using a case? Try without the case and see if you are experiencing the same thing.
Using case.
I tried with case ytd ok, today cannot
Then search press here there then enable one function then can liao.
But can’t remember how come I dis-enable earlier
endlssorrow
Is under accessibility—> Touch, touch accommodation menu, if off then the right button cannot be used anymore
