Redmi Note 9
amazingone
I installed china apps watch movies, but seems cannot project full screen. :o
I still see truncated at camera and the notification there. :o
Because the screen aspect ratio is different from the movie so cannot put it full screen. :o
I think it's the software that won't don't let the app show at the notification status bar, otherwise the camera cutout will block content. :o
Posted from PCWX using HUAWEI ALPS
teoph04
What notification you want?
:o
you can goto your whatapps and manage it?
:o
I select every option but inside nothing to select leh... Haha
Posted from PCWX using Nokia 7 plus
Broadwalk
This is a clear edge Tempered Glass ? If so, the coverage is typical. The smaller cut is to prevent white edges from forming near the edges.
All.smartphone has a curve edge these days.
That is why alot of company produces Tempered glass with edges printing .
Anyway, I ordered Privacy Tempered Glass from Taobao and is using it now. Not bad.
Share link in case I want change a new one.:o
Broadwalk
Yeah I try changing the full screen display also cannot so I was thinking the same line as what you shared.:o thanks for confirming that.:o
Broadwalk
Nothing unless you change something from your own music files?:o
I manage to figure out , you change notification tone by going setting, notification and you choose the theme, mine is droplets.:o
Broadwalk
Eh no leh... I can't even find default notification ringtones also haha
Goto setting, notification you will see the 3 themes and 1 others then you can choose from there.:o
How’s your screen protector?:o
teoph04
:o
How*********s your screen protector?
:o
Ah ok thanks... I haven't tried yet... How's yours?
Broadwalk
Like I shared the protector seems slightly smaller than the screen.:o likely to change after a while.:o
I had a hard time remove phone from cover.:o
teoph04
:o
:o
:o
Wah Sian... Then likely to change mine too...
Posted from PCWX using Redmi Note 9 Pro
teoph04
Yes it*********s abit smaller.
:o
just use it and wait for better screen protector to be available.
:o
Yours for the black borders? The original screen protector also smaller than the screen actually.
Broadwalk
I did not notice the original thin film protector I opened and apply my screen protector with the black border then I realise the whole piece is actually slightly smaller and narrower in both length and breadth.:o
teoph04
There's actually a film protector on it... MIUI 12 still not available?
Sent from HMD Global NOKIA 7 PLUS using GAGT
Broadwalk
I removed that thin film and apply the screen protector straight.:o no point using that thin layer of protector.:o
MIUI 12 should be available later.:o now I no more update despite I tried updating.:o
