Prism+ TV
TSAcad2111
Hi anyone has prior issue to turning on their Prism TV? Just received mine today and upon plugging into the power socket, the power light is blue but it cannot be turned on. :(
Guyver
their tv series not so stable in terms of quality. i have no issues with their monitors though .. for this kind of price . cant find anywhere cheaper .
i1magic
For those of you that bought Prism+ TV, can you all do the Chroma Sub Sampling test :
https://www.rtings.com/tv/learn/chroma-subsampling
It is basically displaying this picture on the screen :
At original 100% size and then see whether can you read the last 2 lines legibly.
Do share your TV model and size also.
Anybody can do a Chroma Subsampling test on Prism+ TVs?
MFriZaL
Issue with E65.
For those who harbour to purchase the Prism TV, I would suggest that you hold it 1st.
The unit that I got had continuous issues with Netflix & eventually after some persistence, my concerns end up with Tech Support Level 2. But to be honest Level 1 & Level 2 may just be the same chap & see how best they can do damage control. Left review feedback on Prism main page, guess what since I give them 3 stars, they obliterated my comments. I guess they only want to see & hear the good things...typical fascists mindset.
As till now, the issue is still persistent. & the Level 2 Tech Support specifically mentioned the issue is persistent across all models & they are aware of this issue since the launch E43, but instead of resolving the issue before releasing the newer models, they still proceed doing so most likely based on greed & ignorance.
https://imgur.com/YLa8KBc
https://imgur.com/ykNCcR9
大蛇丸 Orochimaru
it is wiser to buy a common brand like xiaomi. Furthermore this prism+ tv is running linux instead of android.
MFriZaL
Actually now that you said it I do remember that the TV switch on by itself.
They replied to my email:
How did you get them to refund you?
Haha they didn't even offer me replacement or refund.
Hi,
I'd a Prism rep replying back to me.
If you are seeking for a full refund (which I'm resorting to since the problem is getting more & more persistent).
I've attached the reply from them, which you may make use of it to (if you need to) asking them for a full refund. At this point they don't seem to care less about the issues, cause if they do then they should not have had released the E65 knowing that the issue was already there in E43 unit.
https://imgur.com/PQX69f3
chaiscool
Tcl would be better than xiaomi since still have android tv but confirm get Netflix and got local 1 year warranty.
scorpiokeong
did you manage to resolve it? i got my tv set a few days ago, was working fine until today same issue as you. power light is blue but it cannot be turned on
Guyver
get aiwa 55" at $599 just recently . its 4k tv . Andriod interface .
i1magic
Any reviews or feedbacks? Most seem to go for xiaomi and tcl. Even prism / hisense like more buyers.
I bought Xiaomi Mi TV 2 55" back around May 2015. Seems ok lah. TV is still running in my living room. The software side will be crap because it is export set and doesn't even support PlayStore well. NetFlix don't even think.
Managed to side load and tahan till now.
