[NAS] Synology NAS owner club!
batniss
I found this :
Toshiba MG06ACA800E 8TB 3.5-In 7200 RPM Enterprise Hard Disk Drive
Selling : $337.05 (Excluding delivery)
Can't really find much info on this drive but based on specs, looks good.
Anybody here use this drives?
yes, have been using it for more than...
stam
hi guys,
i have a existing 4TB HDD, now i added another 8TB HDD.
Its running under SHR. The usable space is only 4TB? what about the balance 4 TB in the 8TB, can i set it to without redunant and use the space?
I cant seems to create any new volume, all the options seems greyed out. Thanks.
bullshitregister
Can anybody share any good deals now for HDD's? Prefer around 10TB size if possible, but happy to go for best $/TB. Also happy to shuck and wait for delivery if needed.
Thanks in advance!
batniss
hi guys,
u can't
10chars
lhseong
Hello all, I have 1 issue with my NAS.
Slot 2 of My DS212play not able to spin up, checked is not the HDD problem, cause test the HDD in slot 1, it work fine.
Anyone have this kind of failure before ? Thanks
batniss
SATA problem? - maybe faulty port.
batniss
OK. 2yrs+ liao. Is this temperature normal? What is the argah argah room temperature?
i stay top floor, so my house is generally like an oven.. i never measure it before though nothing to measure with but i would say the temp is pretty consistent with any hdd that I've throw at it.
coppermine
Do you think it can fit 80x80x25? Saw a number of people changing thier fans with normal PC fans
I suppose it can fit in DS1511+, based on various comments and review. They are using Noctua NF-A8 FLX, my only concern it's rotatary sensor on older DS1511+ which will still detect as fan fail.
acer23
My synology NAS, harddisk crashed a few times, which brand and type of HD, is more crash safe ah...
batniss
What hdd u using? Why will it keep crashing?
I m assuming you might have the same challenge i have previously which is a NAS issue over HDD. Synology insisted was HDD and i kept swapping. Waste time. In the end a change of NAS resolved everything.
Show your hdd smart health easier.
MeGaBiTeS
Hi all, will I see an increase in performance if I change from 1511+ to DS418 or DS918+? I'm using it mostly for file backups mostly.
existential_reality
Been using the following each for 2 - 3 years straight with very low issues
HGST 4TB (about 3 drives)
Seagate NAS 4TB (about 8 drives
now
Seagate Ironwolf Pro 10TB (about 13 drives)
I did have issues with a WDC Red drive only had one of those, some IO issues now I stopped using them.
I found this :
i1magic
now
Currently, all the hard drives in my PC are WD Black. One of them reaching 5yrs and no problem. The other 2 are about 3yrs+.
existential_reality
Hrmm I guess hard to assess though, unless they also run 24x7 in a multi drive array. Cause have to account for vibrations, and heat etc and usage etc for a better comparison in a NAS environment.
