Preacher1010
- Jul 20, 2001
you using AIO or heatsink for your CPU
I using nzxt x22 single 120mm aio
I helped my friend built with inwin A1 + corsair H60 AIO mounted at the back.
what is the temp while idling and playing game?
when you said 'at the back' meaning outside casing?
Rear, you can put a 120mm fan there. H60 is a slim profile AIO, so it still can fit there as well, just that you need to plan out which cables to insert into mb first before mounting the AIO. Tubings were a little tight as far as i rmb, but so far my fren nvr complain about any leaking or issues with PC.
Currently idle is around 55? Play games Long term can hit almost 80
I had to off the auto overclock plus set voltage at 1.2v
If it helps I’m using a nitro plus 5700xt (almost cannot fit.)
Plus two intake at the bottom. One intake at the side and single exhaust out the back. Fans mostly around 1350 rpm
Won't it have overheating issue?
Cooler Master just release their new ITX case. Looks pretty good to me.
More pics here:
https://t.bilibili.com/h5/dynamic/detail/398537308255562711
You can't go against physics. The smaller you go, the lesser space for cooling, so the hotter the components. I like small ITX setups, but I also find them worryingly hot, especially if you are getting a high end rig and not going for water cooling (if space permits).
