Samsung Galaxy Tab S6 Lite
MBoI1986
Like still no news on any launches here leh. But saw that Samsung is already working on Samsung Galaxy Tab S7. If that come first, the price of Tab S6 will drop. Might as well get the price dropped Tab S6 rather than Tab S6 Lite.
watzup_ken
I think it runs an Exynos chip, which is not ideal as compared to a Snapdragon 7xx series.
dgeralds
Is it possible to download past year papers (in pdf) and use a pen to write in the blanks in the pdf for a primary 3 student?
If possible, what app will allow it to do this?
metavolta
What us the difference between LTE and Wifi version?
Both models are identical if you are referring to the built quality, processor, ram etc used....
Not sure about the storage whether it is the same for both LTE and Wifi
trenzterra
Wanted to get the S6 Lite as an upgrade to my Tab A 8.0 S pen but realised the processor isn't significantly better and reviews seem to comment on user interface lags, which is really quite annoying (I experienced the same on my Tab A)
Decided to switch to iPad 7th gen and so far quite happly with it... The 128gb version is about same price as s6 lite although it doesn't come with a pen (I bought apple pencil separately). Though it's using old processor and only 3gb ram, it feels very fast and many apps are tablet optimised (except Instagram lol). Maybe it's worth checking out as an alternative.
hkchew03
Nothing can fight ipad
In term of speed on old CPU/model. Rest depends on what you use it for. I ended up choosing S5e over ipad due to sd card expansion, screen for media viewing and the sound quality. Mostly for media viewing, so don't really need so fluid.
Teo Ming Ern
True but the Samsung has 64 GB storage out of the box. For the iPad, you need more space, you have to jump straight up to 128 GB... the base 32 GB really isn't enough... installing just a few commonly used apps and you're about done... no space for much media unless you're only interested in streaming everything... so a lot depends on your use type.
