CPF SA
omgwtflol
Hi,
If the CPF SA Max limit is $166k, what happens to the following year interest generated from the $166k ?
weng0202
Hi,
Stay in SA lor. Only MA will spill over to SA or OA. SA has no "cap" for interest, only contributions can spill from SA to OA.
onegoal
What is Special Account limit now? I believe it is more than 166k
audiovideo
If you sa max is $166k, mean you way pass 55, and likely that amount already become RA. And RA interest remain in RA
onegoal
2018: MA at 49.8k & SA at 166k
2020: MA at 60.0k & SA at least 185k
Seems like not easy to catch up if u don't have at least 6k salary with bonus 2times.
iceblendedchoc
sa max interest still stay in sa. The earlier you max the better, the interest take care of the minimum sum increase yearly
ferrero
Let's say MA is maxed out and one transfer from OA to SA such that the interest generated for SA is enough to offset the yearly increment, one will be able to meet sooner or later right?
update - iceblended answered for me already
ramlee
High Honorary Member
i field sho jelly :(
but ma interest is not enuff to take care of yearly increase wor :(
ramlee
if your house is settled then yeah, otherwise you need oa to pay for house :(
onegoal
At the rate the minimum sum for SA is going, I armchio at the younger generation who started work. They will not be able to hit the minimum sum even if they reach 50 year old. By 2040 SA minimum sum will be 350k.
If CPF cap the contribution at 6k for companies. Good luck to the younger generation.
yoongf
There is no max cap for OA and SA.
The cap is applicable only if u try top up. But if salary or voluntary contribute, only the annual limit applies.
