Where to replace headlights bulb?
iosnewbie
My Honda’s HID headlights bulb on the left side just died. Is there any workshop near Alexandra road which I can go replace?
Mine is a COE car so I usually service it at a workshop at Bukit Batok but would like to avoid going so far just to replace a bulb.
iduncheckmail
Honda where got factory HID ? Mostly is aftermarket xenon blue tinted bulb. Cheap cheap .
iosnewbie
I’m not entirely about this. Mine’s a JDM Accord bought from PI. Drove it for a long time already and this is the first time a bulb has died.
zzt231
My Honda*********s HID headlights bulb on the left side just died. Is there any workshop near Alexandra road which I can go replace?
Search carousel .
Got 1 guy sell many lights bulb, v high review.
He can install also.
Should be cheaper than workshop.
Posted from PCWX using never on bended knees
myviowner
Search carousel .
Search in Carousel : lightbulbsg.
Previously done by him. Nice chap. Drove to his place and he comes down with the set of light bulbs to replace.
Cheaper than workshop for sure. :)
Location at 440C Fernvale Link
iosnewbie
Thanks for the tip.
I’m just concerned if meeting a carousel seller during post ** phase 1 is legal or not.
If possible, I’d like to visit a workshop at Alexandra as its closer to my home.
myviowner
Thanks for the tip.
Final decision is up to you bro. Scared then suggest got to a workshop.
ralliart_ray
Thanks for the tip.
You have the answers for urself, just drop by Alexandra and find a shop to replace the bulb.
I recommend that Fernvale guy as well. Tried one
LouisSaha
I go to my regular workshop.
Few bucks only. I remembered I replaced my headlight bulb, 5 bucks.
hawthorne
Last time bro Allan changed for me. He come all the way to my car park. Not sure he still do this or not
Sent from 10char using GAGT
bboyirving
if stock is running on hid, likely bulb blow nia. no need replace ballast. cheapest solution will be like what the others say, buy the bulb from the carousell guy. otherwise any car servicing workshop in alexandra can do also but slightly more exp.
EJB
You might wanna replace both bulbs, else 1 side will be brighter than the other.
cscs3
Honda Civic FD series is factory HID bulb. Not sure if JDM Accord. If HID, there is also a possibility that ballast is bad too. If this happen, you may ending up changing both side and you may not be able to get the same type of ballast for JDM model.
myviowner
Are the workshops in Alexandra opened for biz already?
Go spin one round there. The big corner workshop (Along that stretch with many motorcycle parked outside for sale) should be open.
Bulbs blow ask them change a set not more than $10.
If cheapo abit, take that blown bulb, walk across to the rear of the market, there is one old school spare parts stop. (Facing the road)
