[Official] Playstation 5
ichinisan
normally i dun buy the 'fat' original version of PS. i normally get it when the 'slim' version is out. the 'fat' version will cost the most also since it is brand new release also.
That's true. Hopefully the slim version will be better.
xtwis7
They said the size is necessary for cooling. I won’t compromise that for a smaller console though. Never really liked the slim approach because just like PCs, smaller casing is not for peak performance builds.
ichinisan
Is it really true that the size affects the cooling?
Recce5
i will wait for 2nd gen. 1st gen always got hardware problems. ps4 1st gen got blod, auto eject, heat issues etc.
btw did they mention anywhere ps5 will continue with psn plus?
I have all 3 gens of the PS3 hardware, PS original, PS2 original and PS4 Slim.
Did Sony mention any changes to PS+? If not, it should behave the same way on PS5 as it does now on PS4/PS3/Vita now.
Recce5
Both should release around the same time. So you can buy both or one or the other.
Guess it depends on the kind of games you like. If you look at the exclusive games for each platform, PS4 >>> Xbox One. I would imagine it'll be similar with next gen.
Indeed, plus PS5 should also have lots of Japan originated games which all the Xbox generations lack due to Xbox systems not selling in Japan.
WhiteHunter
I see. That means the slim version could be more prone to overheating?
slim use less power and generate less heat. in a way it is not prone to overheat despite being slightly smaller.
users whose ps4 console be it slim or standard have overheating problem is due to dust build up and putting their ps4 in a poorly ventilated place such as cupboard while playing. need to put it in a well ventilated place without blocking airflow and clean the air vents regularly.
ichinisan
Same sentiments too. Airflow is really important.
xtwis7
But if the slim version uses less power, it must mean sth. It can’t be the same processing power while consuming less power, otherwise that would make the first ‘fat’ console look damn silly.
WhiteHunter
the 1st fat console has been discontinued. there is no difference between the fat and slim console in terms of processing power, memory etc. the only differences are slim is lighter, slightly smaller and uses 85w less power.
