Xiaomi MIPAD 4
Gixxerfied
Recently flash my mipad 4 after getting stuck previously becos it doesn't like connecting direct to my mobo usb3 port. Recently got a usb3 hub and it works(still connected to my usb3 port)..
Flash with pixel experience using twrp.. Renewed and snappy..
hermes76
Pheww.... After multiple attempts finally got it up, even kena a bootloop at 1 point... Hopefully everything works fine. Thanks bro for the advices... Whoever wanna flash to LineageOS1.7 and need assistance can let me know.
Sent from HUAWEI EVR-L29 using GAGT
bigass
can share with me how to do it
hermes76
https://www.getdroidtips.com/lineage-os-17-xiaomi-mi-pad-4/
Sent from Xiaomi MI MAX 3 using GAGT
Yah, this 1 of the site I reference to, also xda forum n gadethacks. Got time I'll juz write up how I get mine up, from a noob's perspective.
hermes76
How I flashed my MiPad 4 to LineageOS1.7
Disclaimer: I'll not be responsible if my steps below got your MiPad 4 bricked.
Things you need, for those programs, u can use the name & download online:
Start below only you have prep all the above.
Unlock Bootloader on your MiPad4
1. Run miflash_unlock.exe from miflash_unlock-en-4.5.514.47, follow the instructions to unlock your MiPad4 bootloader, you need your Mi Account.
Booting into TWRP Recovery
1. Enter Developer Options and enable USB debugging
2. Connect MP4 to your PC/laptop
3. Power off your MP4
4. Press & hold volume down + power button on your MP4, release when you see the Mi logo, you should enter Fastboot.
5. On your PC/laptop, open CMD in the folder where you extract the ADB-Fasboot-And-Driver-v1.4.3
6. In the command, type fastboot devices, you should be able to see your MP4 serial number listed.
7. Then type fastboot flash recovery.img
8. After finish, type fastboot boot recovery.img, this will reboot your MP4 into the TWRP Recovery main menu.
Nandroid Backup
1. You can follow the below link to perform a backup in TWRP, i did it anyway
https://android.gadgethacks.com/how-to/twrp-101-make-nandroid-backup-restore-your-entire-phone-0175300/
Flashing the new OS Ref: http://theupgradeguide.com/2019/07/28/install-android-9-0-pie-on-xiaomi-mi-pad-4-lineageos-16-how-to-guide/
1. Still in TWRP, go to Wipe > Advanced Wipe > Select Cache, Dalvik/Art Cache, System, and Data. Then Swipe to Wipe.
2. Then go back to TWRP main menu.
3. Select Install, locate the LineageOS1.7 ROM zip file and Swipe to Confirm Flash.
4. Do the same for the GApp zip file.
5. After Gapps flashing completes, Select Wipe cache/dalvik from the bottom left side of the screen, Swipe to wipe.
6. After wipe completes, Click on Reboot System.
* In case, you have a problem with mounting your internal storage or your storage shows 0MB like what I encountered, you can refer to the below link. Then I did some adb commands to copy the ROM and GApp back into internal storage.
https://appuals.com/how-to-fix-twrp-unable-to-mount-storage-internal-storage-0mb/
Good Luck!
ekardo
what's the diff with xiaomi and lineage ? can't seem to find any info on google..
hermes76
Juz different OS, on Xiaomi u got all those Mi Chinese apps, a custom ROM like Lineage, u dun get those, juz the basic.
Sent from Xiaomi MI PAD 4 using GAGT
zoomzoom5535
Hi guys
Do you know any working Netflix APK which I can download?
Try a few , but none of them seems to work.
Thank you very much in advance.
zoomzoom5535
Strangely, about 6 months ago, I can install Netflix V 6.26.1without any problem and can watch in HD some more.
But now I wanted to install the same for my second set, Netflix just does not work anymore even the same version was installed.
