jasonwsc
- Jun 28, 2013
try using other sata ports
sounds like ur mobo faulty. rarely both ssd faulty at same time.
My SSDs are both m.2s and attached to the mobo. No sata cables involved.
Before you return the motherboard for testing/RMA, try rolling back your BIOS to an older version, and then reflash it back to the new version. The crashes could be due to corrupted BIOS. This happened to me when I flashed my Asrock X470 board to the latest P3.90, which I subsequently downgraded to P3.60, which corrupted the BIOS. Strangely when running stress test, it works perfectly fine and stable. But when gaming, it keeps crashing out or BSOD. So I bit the bullet and flashed it back to P3.90 after trying to do a clean install of Nvidia driver that did not help. After flashing the BIOS back to P3.90, it seems stable for now.
This is a good thing to test and I would go the extra mile and if you have a spare partition or hard disk re-install windows and try the game/app that you experience the most crashes with.
It’s easy to just point this is wrong or that but ultimately there needs to be a fair bit of troubleshooting done to get to the bottom of the issue. IF you listen to some it could be RAM,.. go RMA that then it still happens,.. next RMA motherboard,... maybe then its fixed? WOW the legwork involved in that is no joke!
I feel it’s worth a short to reflash the BIOS. The BSOD may be due to a corrupted BIOS. And honestly, besides the difference in error you are getting, they symptoms looks quite similar to what I experienced.
Flashed the 3.20 BIOS again and enabled XMP. Seems stable for the time being, will monitor further. Thanks.
Quick update, the PC started crashing again.
I backed up my files and reinstalled Windows, but any time I transfer large amounts of data, the PC will BSOD with WHEA uncorrectable error. I cannot find any dump files inside the system.
I don't think it's a RAM issue, as stated earlier using 1 stick of RAM from another PC still caused crashes. Also don't think it's an SSD problem since transferring files or installing the Steam library to either will crash. Probability of both SSDs dying quite low right...
Probably gonna RMA the motherboard soon, if it doesn't work then RMA CPU. Followed by RAM then SSD.
Specs on the right >>>
So recently my computer starts to BSOD like nobody's business.
1. Play Overwatch for about one hour, assets suddenly stop loading, then black screen with cursor still visible before BSOD
2. Play GTA V for about one hour, exactly the same thing happen.
3. Updated to latest BIOS, running at XMP settings, still crash.
4. Ran MemTest64, no errors found while running but computer freeze again.
5. Computer runs perfectly fine browsing the web for the whole day.
BSOD error codes: ks.sys died, critical process died, System service exception, kernel data inpage error
I'm pretty sure it's the Crucial RAM problem, used for less than half a year but any suggestions are welcome. RMA to US ***** troublesome now.
Edit: Seems like AsRock motherboard issue, will update. So out of the 3 AsRock boards I bought, all 3 have been RMAed. Excellent.
I backed up my files and reinstalled Windows, but any time I transfer large amounts of data, the PC will BSOD with WHEA uncorrectable error. I cannot find any dump files inside the system, changed all the settings but the BSOD will restart at 0%.
What version of windows did you reinstalled. There seems to be some issues with windows 10 may update 2004 with some hardware configs. Might want to try older versions of win10 or best with Linux to totally rule out OS issues and confirm it's either cpu or motherboard.
In this case, if your motherboard comes with local warranty with Tech Dynamic, bring the board, CPU and RAM together and let them test on the spot. Problem is that most of us don't keep spare parts for troubleshooting, so better to let the distro do it themselves to confirm if the issue is due to the motherboard or not.
Good suggestion, in voting mood now, so i vote for this.![]()
He should have installed 1909 as 2004 has an opt-in element now. I. have reinstalled and NOT installed 2004 as I ran into multiple issues including BSOD!
Anyway, most distro will prefer you bring these items down for troubleshooting. In addition, we paid for this service anyway when paying more for local distro warranty.
If distro willing to help then ok. Some will only strictly test the items that belong to them.
