POCPHONE F2
DigDub
Got tempered glass and nillkin nature tpu case from carousell. Tempered glass no issues with the screen sensitivity. I like the case as it's quite thin and has subtle bumpers around the corner which protects from falls and provided good grip without being over grippy such that it's hard to put in and out of pocket. It's also light grey on colour so should not be obvious when dirty or yellow.
https://sg.carousell.com/takatika23/
The phone comes with volte disabled by default. Can press *#*#86583#*#* in the phone dialer to enable volte.
Nakedtoes
The glass very easy to apply hor? Do u have finger print unlock issue occasionally? I think the sensor is slightly above the finger print icon.
DigDub
The glass is very easy to apply. It come with a frame to put over the phone for alignment and just drop the glass inside it can liao.
Sometimes have fingerprint unlock especially if fingers oily. Mostly is ok.
Anything_Whatever
Got another launch event just announced on Xiaomi Facebook on 2nd July
Just an announcement for local launch and availability in physical Sgp stores...
Saves ppl the trouble of buying from oversea e-commerce platform.
Don’t think is new model announcement.
DigDub
Don't know if they will launch both storage options or not. Think price will be $899 for the higher storage model?
ranmaru1987
I'm using million nature tpu case as well.. but front facing camera will be blocked a little by the case..
Sent from Xiaomi REDMI K30 PRO using GAGT
DigDub
Ya now that you mention it, the case blocks a little of the camera.
Nakedtoes
cut off that portion that block the camera... no issue to the case
Anything_Whatever
Took about 2 hours to transfer about 59gb of data from old Redmi A2 using mi Mover. Phone running quite hot, battery depleted at least 55%.
BTW Redmi A2 was running Android One so abit of a hassle if use Google Assistant method to transfer files and it doesn’t have mi Mover ... so a heads-up to those currently using Android One phone they will need to install the mi Mover app from Google playstore.
Beefsteak
I'm using the Nillkin Nature tpu case too. Quite a nice case. But after applying the tempered glass. There is only a very slight raised lip to protect the screen so its like the edges sit almost flush with the screen.
