minuteez
- Aug 21, 2004
Original Post:
https://www.instagram.com/onepluslitezthing/
OnePlus event, 30 June, 2pm CET on IGTV.
Hope its a solid mid-ranger costing less than $500
Unboxings/Reviews:
Enable VoLTE on Nord
Disclaimer: Usual I not responsible stuffs.
I couldnt dload the QPSt tool linked in the post so I dloaded new QPST tool from HERE. Worked for me.
WARNING! @Gixxerfied mentioned the following side effect from doing above. But doesn't seem to affect the Nord.
Remove facebook bloatware:
Workaround for Google apps that flicker
Unboxings/Reviews:
Unbox Therapy AR launch & Unboxing
Some reviews:
Some reviews:
Reposting for convenience. To enable volte for oneplus devices:
Guide to enable VoLTE
1. Download these 4 files:
QPST (Install on PC) - https://qpsttool.com/qpst-tool-v2-7-474
Qualcomm Driver (Install on PC, select WWAN option) - https://androidfilehost.com/?fid=11410963190603864074
Oneplus logkit (Install on phone) - https://forum.xda-developers.com/attachment.php?attachmentid=4763657&d=1558542807
Oneplus Engineering Mode (Install on phone) - https://www.apkmirror.com/apk/onepl...-0-171117173719-25c8842-android-apk-download/
2. Install the files as mentioned on PC/Phone
3. At phone dialer, key in *#800# > oneplus logkit > Function Switch > Tick "VoLTE Switch"
4. Reboot the phone
5. At phone dialer, key in *#801# > Engineering mode > ON "Full-port Switch"
6. Launch PDC Software on your PC
7. Select the Qualcomm WWAN Adapter
8. Right Click "Oversea-Commercial_DS", deactivate Sub0/Sub1 (Sub0 is SIM1, Sub1 is SIM2)
For me, M1 sim is in Sub0, so i only deactivate Sub0
9. Scroll down, and find and Right Click India-VoLTE-Vodafone > Set SetSelectedConfig > Sub0/Sub1
10. Once done, click on the Activate button below to activate the VoLTE Profile
11. Reboot your phone
12. Go to your Settings Wi-Fi & Internet > SIM & network > SIM 1/2 > Toggle on VoLTE
13. If everything is successful, the VoLTE icon will appear on status bar
Disclaimer: Try it on your own risk, dont claim from me if your phone up lorry![]()
Just chime in. Changing the profile will enable volte etc etc but if you are gonna sent sms text to those 5 digits number to sign up for maybe cc promo, the sms won't go thru.
Did the same thing for my op6t to enable volte for tpg card last time(which also allows me to call/sms), found out I couldn't send those short number sms..
No workaround sadly..
I had to remove sim, plug into an old BB i have lying around and send out those sms
sms like this..
SMS YOLOULTRA<space>NRIC to 77862.
Looks like its not an issue on the Nord. Both circles & MyRep sms went through.
