Official Shiny Things thread—Part III
swan02
Thanks, but I’m trying to balance out my portfolio which is now heavy with value stocks and reits and wish to have a specific allocation to tech stocks which I’m incredibly low in.
So what are the recommended and popular global tech etfs ?
Um. Kinda depends what you want—global tech? US tech? Just a generic Nasdaq-composite ETF (which is not just tech! Nasdaq ETFs are only about 48% tech)...
Either way, if you actually want a tech-sector tilt, the go-to is IUIT, listed in London. Though be aware that you're absolutely chasing performance here, and if tech stops being trendy like it did from about 2000-2007 you're going to be in for some pain.
What about the QQQ equivalent in London - CNDX, for Long hold along with IWDA?
Sinja89
So I've purchased some stock on IBKR, USD.SGD commission 2.79, IWDA commission 5.
2.79+5= 7.79 USD
Monthly minimum commission is $10.
That means IBKR will automatically deduct 2.21 from my cash account?
CWL84
2.79+5= 7.79 USD
That's right. The fee will be deducted during the first week of the following month but you won't be charged any monthly inactivity fee for the first three months.
Shiny Things
What do you think about ROM then? I feel it track very closely to NASDAQ movement
ROM is a 2x-leveraged ETF that tracks the Dow Jones Technology index. It's not a Nasdaq ETF.
Like any other leveraged or inverse ETF, ROM is only for day-trading. Leveraged and inverse ETFs always go to zero over time, because of a thing called volatility decay.
The easy way of explaining volatility decay is:
If the underlying index goes down 5% on day 1, then up 5.25% on day 2, it's flat. But a 2x ETF on the same index will go down 10% on day 1, then up 10.5% on day 2—and it'll end up down 0.5%, even though the index is unchanged.
And that happens every day—so you'll repeat that decay 250 times every year, whether the market goes up or down, by a little or a lot. Half a percent every two days is a bit of an extreme example, but if the ETF decays that much every day, then in a year's time, the index would be flat but the ETF would be down forty-seven percent.
This is not a "probably" thing, it's a "definitely" thing. It's an immutable law of math; it happens because these ETFs promise a multiple of the daily return of the index. It's such a well-known thing that at one time, people were able to make pretty decent money by shorting 2x leveraged ETFs and their corresponding 2x-short ETFs and just going to the pub. And this is why you never, ever, ever hold leveraged or inverse ETFs for any period longer than a day.
Also, on top of everything, ROM pays dividends. And because it's listed in the USA, you'll pay withholding tax on those dividends - 30% of all of it goes straight to the taxman. Not great, Bob.
If you want exposure to the Nasdaq Composite, buy CNDX LN.
If you want exposure to technology stocks specifically, buy IUIT LN.
If you want to punt tech stocks intraday, buy XLK on margin and don't hold it over an ex-div date.
kram62
2.79+5= 7.79 USD
Just a correction, USD.SGD commission is USD 2. The 2.79 you see is expressed in SGD (right side of USD.SGD).
And for buying IWDA, you can lower the commission by changing to tiered pricing instead of fixed pricing. Then the commission is about USD 1.91 instead of USD 5 for typical small investment sums.
Exact cut off where fixed is better is for orders above about 9k-10k usd if I remember the previous discussions correctly.
MichealScott
2.79+5= 7.79 USD
Also, if i am not wrong, the 2.21 will be in SGD. So make sure you have SGD in your account. I changed all my cash into USD and when is time to pay the min. fees, IBKR automatically changed my USD into SGD to pay for it. :(
BBCWatcher
It depends on your base currency selection. You can change your base currency from Singapore dollars to U.S. dollars (or vice versa) if you wish.
swan02
Regarding nasdaq 100, I can only find CNX1 LSE which cost like 45k usd per share and CSNDX EBS which is SIX Swiss exchange In IB. I can’t find the CNDX.L
Between the two, I would pick the domicile EBS ? Will I still enjoy same tax implications with LSE domicile ?
Like I mentioned upthread, CNDX is heavy-tech (like 48%), but it's not entirely tech. If you want pure tech exposure, IUIT is the right answer.
swan02
My observations tells me that tech and reit stocks are doing very well thanks to a low interest rate environment.
Tech stocks has an added benefit that they can borrow cheaply to grow even quicker which reits can as well. BUT tech stocks will also do well when interest rate rises due to having an abundance of cashflow, whereas reits would be killed.
So it looks like tech has plenty of advantage on both sides of the fence. Only problem is it’s supposedly high valuations but is it really high ? It hasn’t even reached the stratospheric proportions as in the year 2000.
Hence a narrow split of similar proportions between Tech, Biotech, financials and reits is all I need for a decent diversified portfolio for the future ?
Any critiques ?
CNDX.L is around USD560 a share now, listed on LSE, domiciled in Ireland
Regarding nasdaq 100, I can only find CNX1 LSE which cost like 45k usd per share and CSNDX EBS which is Netherlands ? In IB.
