Knightoftheblackrose
- Oct 18, 2010
ASUS is coming out with the newest AX 89X router . Price is $600 plus.
The AC 5300 router is always priced at around $500 ( with Standard Deviation of $100).
If I were you , I would buy the AX 89X router.
( My AC 5300 is still going strong, so I can’t upgrade ... yet
No idea on this Carousell as I do not really use Carousell. And I am not good at finding lobangs.
RT-AC5300 is a high end router (Tri-band AC router), so depending on the price you find out, you may want to consider other routers like RT-AX88U (dual band WiFi 6 router).
