Maybe should let ppl note that for the molex to 3/4pin, do not daisy chain them into 1 moelx header. If not, it will kaboom like dat guy's 4 fans.
Daisy chain the correct way. Not sure if u still have his pics or not.
mine kaboomed. 3 fans.
but maybe u r talking about my fans anyway haha
this is very important because i cannot find from google any detailed instruction for molex fan installation. good for people need to install more fans but not enough header on mobo
anyway just to add too, I am not sure if the daisy chain thing caused the boom. because I have plugged an extra fan header from the daisy chain into the mobo which is not necessary, or it is the reason for the boom. currently running them parallel instead of in series just because I scared it may be due to daisy chain all 3 to 1 molex.
i changed 2 variables after the boom: run 3 molex fans parallel and remove the extra connection to mobo. so i also dono which one is the real culprit. a search on google seems to suggest that running daisy chain with up to 4 fans per head is safe.
