Redmi 9 series
solarboi
RedMi 9 vs note 9s. Which will be a better buy? Just using as secondary phone for playing games
TIA!
davidwong
You answered the question yourself leh if you want to play games most impt is soc and ram which is this case surely be note 9s la
TIA!
carboy00
Saw Xiaomi Singapore Official Global Store Shopee Redmi 9 listing, quite a number of buyers bought thinking there's NFC, then to realise there isn't and gave a one star review. Their listing also quietly removed the mention of NFC after leaving it there when it first started selling. :s22:
davidwong
Of cos they will leave it there is to General the initial sales, after that remove it lo but the sales would have been made, it’s not a mistake but a sales strategy if you complain they will then direct you another locally avail nfc capable note 9 variant which then you will have to buy another phone hence another sales and since the Redmi 9 phone is less than 200 seldom
Ppl will refund or make a big fuss just keep it as spare phone.
davidwong
Again this is not xiaomi ya but the local xiaomi fault but then this strategy is been used world wide esp in China
Angtehkor
Saw this redmi 9A on shopee some seller selling below $120. Feel like getting one but this phone use UBS cable not type c and charging only 10 watt very slow for 5000mah phone. Dunno whether want to get a not
RLWZ21
well if u are like me want a type C port...best stay away from it. since more and more phone are going type C.
carboy00
Better to get Redmi 9 with Type-C. I have a Redmi 8 with 5000mAh with Type-C but bundled charger is only 10W and the charging is slow.
Posted from PCWX using iPad mini 2019
carboy00
Of cos they will leave it there is to General the initial sales, after that remove it lo but the sales would have been made, it*********s not a mistake but a sales strategy if you complain they will then direct you another locally avail nfc capable note 9 variant which then you will have to buy another phone hence another sales and since the Redmi 9 phone is less than 200 seldom
They did the same with the Note 9. Considering the price gap between the NFC enabled Note 9 Pro and Redmi 9 is quite large, don’t think people will actually compare the two. The local distributor also keep publicising the Redmi 9 upgrades from Redmi 8 chart from European market with the mention of NFC....
davidwong
How can it be the poster which are imda regulated part of your equipment packaging requirement will make a mistake and left in the final retailing poster and only took it off after some time after the initial sales?
They are not a newbie company launching their 1st or 2nd phones.
hkchew03
That should be considered as false advertising instead of strategy... Claiming a Vios to have a v12 engine?
davidwong
Yes hence once large no. Of ppl bought and to accumulate enough “feedback” then they “oops” change the poster lo
Quite common tactics in sales la if you go into sales job you will find out.
There is not such thing as “mistakes” or “mistakenly leaked” if you know what I mean it’s all part of the marketing strategy
Angtehkor
But 1gb ram so fugging low how to use the phone. If install a lot of apps will the phone lag
Redm 9A is 2GB RAM plus 32GB storage.
https://www.gsmarena.com/xiaomi_redmi_9a-10279.php
Still 2GB RAM is too little today. The last Android phone I bought with 2GB RAM was the Samsung Galaxy S4 LTE+ in Sept 2014. From 2015 onwards, Oppo R7, Mi Max 1 and Realme 5 all have 3GB RAM. Then Huawei Nova 3i, Oppo R11S and Huawei P20 have 4GB RAM. Last one I bought in Dec 2019 Huawei Nova 5T has 8GB RAM.
Redmi 9C got both 2GB and 3GB RAM version.
https://www.gsmarena.com/xiaomi_redmi_9c-10278.php
davidwong
Huh bro which version you bought the local version I bought and hk version I know from Frankie tech are 3/32 and 4/64.
Local version don’t have nfc hk version have and I think a bro also bought from other country version also has nfc
I think he was talking about the new RedMi 9A.
Angtehkor
I haven't buy yet. Thinking only. Some more is not type c
davidwong
If you only need a basic phone this is one of the best value for money already, but do get the one with nfc I think the bro said 190.
Becos the next phone that has nfc will be the note 8T / 8 pro already then that is at lease 100 bucks jump in pricing
