Dash EasyEarn
TsukiSG
Is this mentioned anywhere in the FAQ. It means this exceed the max 2% for premium if you take into consideration compounding interest effect!
According to their policy illustration:
'Account value is calculated as: The single premium paid plus a) any ad-hoc Top-up(s); and b) accumulated interest; less a) any partial withdrawal(s); and b) any partial withdrawal(s) charges. Any interest payable will be credited into the Account value at the end of each Policy month. If the average daily Account value for the Policy month falls below S$2,000, no interest will be credited for the Policy month.'
'Interest is calculated based on the daily Account value and credited into the Account value at the end of each Policy month. If the average daily Account value for the Policy month falls below S$2,000, no interest will be credited for the Policy month.'
alex22
Anyone check the floating interest amount in the app?
Does it seem to tally with
(Principal*rate)*(days from policy/365)?
Mine like dun seem to be 2.00% rate leh, I never do any withdrawal since my first single deposit above the 2k requirements
sansanjikikut
So if put in max 20k from the start does the 2% still apply on interest gained of say 33$? Leaving balance of 20033.I don’t think so man
Mickey01
yes .... i noticed that too. The app was down for maintenance the whole of yesterday and it seems there was no interest credited.
alex22
I just loaDed the app and the amount is updated liao, rate still seems a bit off.
At $20k principal example per day at 2.00pa (365days) should work out as $1.095/day.
The amt i am getting on calc is a bit lesser.
They seem to be doing 2 decimal only
reddevil0728
Did you do compound interest? Or simple interest?
TsukiSG
My understanding:
Same interest rate apply on both premium and monthly interest, making EIR equal to 2.0% p.a. for the first year.
That is, if put in 20k from start and no withdraw, after 1 year, total interest is $400.
If treat it like a saving account, the interest rate should be around 1.982% p.a.
A rough calculation: Jul the first month, you get around $20,000 * 0.01982 / 365 = $1.086 interest per day; Aug the second month, $33.67 interest in, and you get $20,033.67 * 0.01982 / 365 = $1.088 interest per day...
Trazora
Their calculator is not consistent with what is written here, it just show simple interest.
TsukiSG
Actually they are consistent.
Calculator tells you how much you can get after 1 year if you do not make withdraw, which is 2.0% of your premium.
Policy illustration tells you interest is calculated based on daily account value on a compounded basis, but without saying the daily interest rate, which is slightly lower than 2.0% p.a.
Another Etiqa's product, ELASTIQ, is also doing the same way according to that thread.
alex22
My understanding:
So all in all if 20k principal untouched after 365 days will yield $400.00 no more no less, meeting their product obligation either way the calculation route
sansanjikikut
Yes my point exactly. The 2% does not apply to earned interest along the way assuming you have 20k in there from the account opening day.
But it should apply for those with less than 20k? :s11:
Trazora
Even for those with less than 20k, the actual interest rate is about 1.982%, 2% is the resultant compounded interest rate
the "Grow Money" on the app still showing that it's under system maintenance. anyone managed to sign up since last week?
TsukiSG
For this account, what is the interest rate if we deposit beyond $20K?
Maximum deposit is 20k, which means maximum top-up value is 20k - premium - previous top-ups + previous withdrawals (include 0.7 fees if any).
If you refer to the amount over 20k caused by interest crediting, same interest rate is applying on whole account value, results in a 2% p.a. compounded interest rate for the first year.
Guojing88
So what this means for maximum Interest is, start with 20k and don’t withdraw any interest that is credited monthly?
TsukiSG
Correct. Just park 20k in and let it grow. After one year should get $400, then see the new credit rate and decide surrender or not.
