Finally got my p40pro... camp in Carousell for 1 month... and last night happen to see a 1 day recontact set from a seller @ $ 750.no GSM no problem .
wow that is a very good deal!
Yes, I wanna know too
Maybe that's why they charge $ for the singpass solutions
GMS still as easy to install as the past leh.
just installed for a friend's p40 pro recently following Youtube guide.
one time gao dim.
Hi ,GMS still as easy to install as the past leh.
one time gao dim.
Hi ,
which youtube u follow? Does Singpass work ? Thank you.
No GSM of course no problem. GSM is 2G standard and no longer supported in Singapore.
I think you mean GMS.![]()
The camera bump on the P40 Pro Plus is noticeably larger than the P40 Pro’s, with the P40 Pro Plus being half a millimeter thicker than its younger sibling. This is because Huawei needed a little extra space to house the new periscope telephoto lens.Quick question, can the p40p and p40p plus use the same phone case ? I see the dimensions and cam module like almost the same
Hi ,
you can follow this video as recommended by another bro here in the earlier post. i used the same video guide as reference.
as for the singpass im not sure if it works cos i only helped him to install, test that the playstore etc is working as intended then i left. but you will most probably need a bypass for singpass to work.
was it a BNIB set?
Bro... Give chance... Too excited to try the new phone..
Bros do u guys prefer p40 pro over mate 30 pro?
