I just went yesterday to see a dentist for a very bad toothache. From what I was told they go like together, root canal then they will put crown for protection. Havent went to the procedure yet, looking for affordable dental clinic
Did my pre-molar root canal 1 year ago. RC is $550, The crown costs $950, but I am still considering if I want to do the crown.
The crown is to protect the RC tooth from breaking or chipping. If the RC tooth is damaged again, then there may be no way to save the tooth again.
I will do the crown eventually (after saving enough) since it going to last a long time in my life.
Your RC tooth not damaged even if never do Crown??? Why your RC so cheap???
So far have been careful in biting on the RC tooth. So far ok. Price for RC should be around there ($500-$700) per tooth.
Mine is molar tooth. Got referral from Unitycare to an external endodontist and was quoted $1150. Mine is feeling pain when biting but endodontist said she cannot see how deep is crackline if never do RC.
Planning to go book at unity denticare harbourfront/clementi because as per website: Root Canal Treatment $400.00 – $780.00. Mine is also molar tooth, from behind the third one (size is like premolar). My first visit is actually on Q&M, initially was told 400-700, then come dentist said cannot do, but can refer to one their outlets for their specialist (could double and reach 1200 and up). Today also, called some neighborhood clinics to inquire cost, then some shared that if doctor cannot do they will refer to specialist. Hearing your case, so now having a feeling that if molar they will only refer to specialist.. here i am hoping I could get a gp doctor as i really on budget. Mind to share which unity denticare outlet you went?
amazing thanks for sharing, maybe i can do same... mind to share which dentist you went?
On side note, ts cereal, sorry for flooding your thread with my mission to seek affordable treatment...
RC charges by roots, hopefully u have only one root inside your tooth then it will be cheaper
crowning wise the cheapest i found was trust dental at jurong quoted me $800 for pfm crown.
you check with your dentist, tell them u do RC and crowning with them, got discount/package or not. maybe can get better deal. just try only, nothing to lose![]()
I done once on 1 molar bottom.Got a cracked tooth myself and experiencing pain when biting. Not sure if should go for crowning ($788-1000) or Endo root canal ($1150).. anyone got experience to shAre .. pls tell me moree...
Just to share. Unity denticare indeed no more rc specialist, likely to refer if molar tooth what they say when I called. I ended up doing mine at B9 Dental, only 500 rc, 25 xray. Next month I come back, 150 core treatment. Crown quote around 700 to 900. So far all ok
