tremor
- Jan 20, 2001
I don't use single dosing. I find my grinds ok leh, beginning and end like not much diff.I have a OCD distribution tool. And I find it useless as well. My most useful tool is a needle.
The problem with single dosing is that the beginning grounds are of different sizes from the ending grounds, that is if you dump all your beans in at once. Which is why stirring your grounds with a tool is so important.
Sent from HUAWEI CLT-L29 using GAGT
So I just shake and tap and tamp.
