The Spectacles Thread. - Part 2
Velton
Alright, firstly this is a ''almost'' islandwide zeiss promo. Almost because maybe some shops ''dont'' promote this promotion.
You can ONLY CHOOSE ONE(pardon the caps. just need to highlight it)
1)Free Photofusion on any lenses
2)Free design upgrade (only 1 level up)e.g. Precision Plus-->Precision Superb
Precision superb-->Individual 2
3)Purchase Zeiss progressive lens, you get an office lens
4)If you purchase myopia control zeiss lenses, you get a pair of single vision lens with blueprotect
5)If you purchase a digital lens, you get a single vision lens with blueprotect
If shops don't want to mention about the other promos, its understandable as sales and all are involve.
Office lenses are lenses that as the name suggests, to be used only in the office/desk settings. It has close to no Distance vision vision(not entirely).
The lens is designed in a way such that if you look straight, your intermediate distance(e.g. computer/desktop) distance will be clear, and if you roll your eyes down, then your reading will be clear. But if you are looking to see distance e.g. driving Then the progressive lenses will be better for you as progressive will allow you to see distance,intermediate and near. Just that for progressive lenses, intermediate zone vision will not be as WIDE as an Office lens.
This office lenses does seem suitable for me. Look at monitors.. look at contracts. Prebyopia OK too right? Other than that.. my eyesight is fine. Thanks =)
Sent from Apollo 13 using GAGT
GANGSTERKIA
Hi, I would like to get advice on getting new lens.
I went to a store to try a sample of the new Crizal Blue Capture UV out to see for myself and it didn't really seem to change how my phone's screen looks.
With the old digital lens I could see a visible reduction of blue light but it had the side effect of making white look yellowish.
Any advice on the prescription I should get? I'm around -5 on my worst eye and the optician recommended me to get Transitions Signature + blue capture at 1.74 for 680.
Based on your prescription, I am assuming/hoping your astig(shan guang) is under -2. Then actually 1.67 might be more than enough. I personally feel 1.74 is abit overkill.
If you dont like the Bluecapture, then go with Prevencia which has the yellowish hue. I personally am a strong supporter of the yellowish hue, i feel it makes it more comfortable for me.
May i also ask how old are you at the moment?
GANGSTERKIA
Yes Sir! If its mainly for monitors and looking at near documents e.g. contracts and all, office lens would be very suitable.
khyun2
Thank you Mr Gangterkia. No worry on the cap letter, in fact really appreciate on your effort to give me so much info where have zero knowledge on the lenses. Thank you x3 so much n enjoy National Day holiday. 😀😀😀
EienShouko
I'm 25. I'm not that big of a fan of the yellowish hue to be honest, which was why I was interested in the Blue capture, but it doesn't seem to do anything when I tried a pair without prescription.
I was hoping to get some advice from people who've either used that or similar offerings like Lumina on whether it is worth it. The optician seemed to be trying really hard to upsell me on expensive prescriptions.
GANGSTERKIA
Honestly speaking,
Lutina/bluecap/blue zero all are similar.
All 3 products works on blue absorb. If you find blue cap not working so well, there is a higher possibility you will feel the same for the others.
But ultimately it’s all subjective and at times placebo. The only one to allow you to feel more comfortable/reduced glare is the ones with yellowish hue or like what the optometrist shirui mentioned in the video that nakedtoe shared.
Hopefully lutina will give you the visual comfort!
Though it’s unfortunate that someone is trying to up sell you.😅 hopefully the next person won’t do the same. Eyezone over here has more experience with tokai lutina.
subfusc
GANGSTERKIA.. Do you think Spectacle Hut is OK? I was quoted $250 for Zeiss progressive lens
Magickiller9
Hi all. any recommendation for spec while using com? I went for lasik previously and had perfect eyesight but the stayhome thing really ruin my vision and my eyesight are getting worse. Any recommendation for spectacles while using computer?
GANGSTERKIA
Do you mind letting us know what is your age right now? When did you do your lasik? Also did the deterioration of your vision only started during ** period. I.e March onwards?
subfusc
Did they mention what progressive was that? Which tier or the name? Zeiss light? Zeiss light 3D?
No.. Not really. I didn't really ask. I would assume it's the most basic one? Zeiss light and Zeiss light 3D... I think the latter is the better one?
GANGSTERKIA
Based on the price, it seems like the light or light 3d basic series.
GANGSTERKIA
I see.. What are the different grades for Zeiss lenses? I checked with Better Vision and they quoted me $400 and up for Essilor lenses
Zeiss starting from their basic(not counting AO lenses)
Zeiss Light
Zeiss Light 3D
Precision Pure
Precision Plus/Asiana
Precision Superb
Individual 2.
Essilor above 400 Based on RRP
Comfort 3.0
Physio 3.0
X design
X Track
Xclusive.
ralliart12
I suggest you either use a double aspheric lens that will reduce the distortion significantly but only for distance or, anti fatigue lenses which will help in relaxing eye muscle when looking at near for Long hours BUT it’s not double aspheric...
What's the difference and advantages of double-aspheric lens? Is it the same as single-vision lenses?
GANGSTERKIA
Check out these articles
https://www.2020mag.com/article/aspheric-and-double-aspheric-lenses
https://www.2020mag.com/ce/double-asphericity-a-free-form-D5313
In short, Lesser peripheral distortion, better clarity and thinner lenses. They are still counted as Single Vision as its only for one viewing distance.
Individuals with high prescriptions are usually encouraged to use DAL.
ultimacloud
Hi,
If i've degree of 600 to 700, usually change every 3 years.
Was thinking on getting transition (driving) with those digital lens (computers).
What type of lens is recommended based on 1.74 index ?
GANGSTERKIA
Hi,
If you want lenses that has blue light filter and can even Turn Dark in the car,
I suggest 1.67 Hoya Sync 3 +Sensity dark+blue control.
