2.5 Gbps wired home network
National Day Offer
$36.71 -26% | Ugreen 2500Mbps USB C Ethernet Adapter 2.5 Gigabit Type C to Lan RJ45 Network Card for MacBook Air 2020 iPad Pro 2020 USB-C Ethernet | https://s.lazada.sg/s.si6x
cscs3
No idea about what you are talking about. You are mixing up WAN side and LAN side.
Whether you are using ONR or ONT, and no matter which ISP or which internet plan (be it 500Mbps or 1Gbps, 2Gbps or 10Gbps), you can have a sub network with 10Gbps or 5Gbps or 2.5Gbps within the home network.
Read the thread here about 10Gbps home network as well.
https://forums.hardwarezone.com.sg/...r-hdb-home-network-10gbe-project-6341518.html
Dont forget router also has LAN port support. Even with WiFi connection, some router already exceed 1Gbps in term of speed. I do not think he means access to WAN at 2.5G speed, with within the router network.
Anyway, without a supported router or switch. You ended up with 1 to 1 connection anyway. So is quite meaningless for 2.5G.
Upcoming 2.5Gbps switch from QNAP. This has been posted early in this thread.
The idea is a fast sub network with a few devices only, say one desktop, one laptop and one NAS, with 2.5Gbps link among them. Link to the other home network will still be 1Gbps.
Upcoming QNAP 2.5Gbps switch
This switch is available from Amazon at US$109 and can be shipped to Singapore.
https://www.amazon.com/QNAP-QSW-110...693640c206317f824dcffbe41fb27e&language=en_US
Edit: not correct, not available yet until Novmember 20 and no shipping to Singapore.
Lon.TV review
alvino
https://m.tb.cn/h.4ZPs5MK?sm=1e06b9 至瀏lan嘂..【TP-LINK 万兆上联以太网交换机 2个SFP+光口4个2.5G电口企业级6口商业高速万兆网络集线分流分线器 TL-SH1206】
Alternative solution but a bit more expensive.
TP-Link TL-SH1206, 4 port 2.5Gbe and two 10G SFP+ uplink.
RMB1080 or S$216.
Product info
https://m.tp-link.com.cn/product_1502.html
Good share dude. The Xiaomi ax3600 too bad don’t support above 1gbps. Else wifi6 with this combo would be perfect
moron+genius
This was available earlier in the the week On amazon.sg and become Unavailable just before I’m abt to pull the trigger. So suay!
Sorry for the dead link. I cut the URL by too much.
Here it is.
Price is US$109.
And I did not read properly. It is not in stock until November 20, and not shipped to Singapore. But you can always try alternative ways to buy it when it is available.
moron+genius
Does those sfp+ 10GBase-T modules also support 2.5/5G speed? Or just 1G speed? I tried buying this tp-link switch after qnap ones become unavailable but always payment error on tmall/TB... wats wrong??
RMB1080 or S$216.
Product info
The SFP+ ports are 10Gbps rated. You need to buy the SFP+ modules in order to use it. I believe it should be compatible with 2.5G/5G as well but better use the TP-Link SFP+ module.
The SFP+ ports are advertised as the uplink for the four 2.5G ports. If you do not have any 10G gear, just leave them open for future upgrade.
Try use Taobao app to see if that works if the web interface got problem.
moron+genius
Used both app n website and 2 diff cards both failed. 😔
10G is for future proofing when upgrade NAS. Currently the 2.5G ports r sufficient.
I see. That is strange. Are you only having problem with this shop or other shops? If only this shop, there are other shops selling as well. You can try other shops.
BTW, I read from the comments that both TP-Link and MikroTik SFP+ copper modules are compatible based on the feedbacks. But no need to use the SFP+ ports now that you do not need 10G.
Nice finding.
Zyxel 12-Port Gigabit Smart Managed Multi-Gig Switch. 2 x Copper 2.5G Ports, 2 x 1/10G SFP+ Ports [XGS1210-12]
S$245.88 but only two 2.5G copper ports.
There are more options but the price goes up sharply.
This one has 8 2.5G ports
https://www.amazon.com/TRENDnet-2-5...=1&keywords=2.5gbase-t&qid=1602394890&sr=8-17
TRENDnet 10-Port 2.5GBASE-T Web Smart Switch, 8 x 2.5GBASE-T RJ-45 Ports, 2 x 10G SFP+ Slots, Lifetime Protection, TEG-30102WS, Black
US$ 395 74+
US$54.71 Shipping & Import Fees Deposit to Singapore
Mikrotik 10Gbps capable switch with SFP+ ports are not so expensive, however adding the SFP+ copper modules to be compatible with 2.5G/5G/10G Ethernet is not cheap. But it is another option which is more future proof.
Ref: switch at S$228 with 4 SFP+ ports
https://shopee.sg/CRS305-1G-4S-IN-M...uterOS-Layer-3-With-SFP-i.43358579.2212585820
CRS305-1G-4S+IN MikroTik Router Switch Dual SwOS Or RouterOS
But the SFP+ copper module is at S$108 each.
https://shopee.sg/product/43358579/1281002269?smtt=0.190081821-1602402607.9
S+RJ10 MikroTik 10G SFP+ Transceiver Copper 10GBASE-T RJ45
any routers around $300 range with 2.5g lan port??
None as far as I know.
Asus RT-AX86U is the closer one with one 2.5Gbe port which can act as WAN or LAN port. It is now selling at S$17*24month=S$408 exclusive to SingTel customers. But you can get from overseas at around S$300 without local warranty.
But if ask for more 2.5Gbe ports, then only the few switch models mentioned above are known to me which are below S$300. They are not routers.
Edit to add: the following can be a router but you need to add copper SFP+ modules which will make the price higher than S$300.
CRS305-1G-4S+IN MikroTik Router Switch Dual SwOS Or RouterOS Layer 3 With SFP+
S$228.00
Unless you want to take risk and order this one.
https://m.tb.cn/h.4bR5dt5?sm=5c08c5
【Intel Gemini lake J4125 4口2.5G软路由V2.0版本】
RMB1050 (S$210) on preorder from Taobao, to deliver after 50days.
Intel J4125 based x86 router, with 4 ports 2.5Gbe.
You will need to add RAM and storage.
