Just to share:
Received my $9.90 TWS F9 BT5.0 ear buds earlier today via EZBUY.
Well, It worked fine.
Comparing it with the cheapest ear buds I own - Xiaomi Airdots:
Pros:
Sound quality: has bass. Pretty decent. Must better than the Airdots for sure which was solely lacking in any form of bass. For music .... Titanum (David Guetta) sounded ok. Lacked detail .. but its still ok.
Connectivity: Bluetooth works. Pairing & re-pairing worked fine
Price: Its $9.90. Cannot complain
Gaming latency: very slight. Not exactly noticeable. Using a cheap BT USB dongle with my PS4. And it connects automatically every time w/o any issues. Bass as sufficient especially during COD Warfare
Fit: Decent. No complains. Came with 3 different tips.
"Touch" controls: worked fine
Cons:
Buzzing sound: Its got this slight buzzing sound. Its definitely noticeable in some of the cut-scenes in Ghosts of Tsushima. But I did not get it when paired with my iPhone. Suspect the problem is my BT USB dongle on my PS4.
Casing: huge. But I guess cos its a power bank also
I've got a AirPods Pro also. Obviously one cannot compared a $300 unit with the TWS. But the TWS is decent enough for me to use with the PS4. I always had issues connecting automatically my AirPods to the PS4. Had to re-pair most of the time. Thus was looking for a cheap pair to play around with. Well, luckily the TWS solved my problem.
[/url][/IMG]
