Bios settings always reset to default when booting up PC..
OutBreak
I already changed to a new CMOS battery but Bios settings don't hold. My motherboard about 8 years old. What could be the problem?
Apologies if it has been asked before.
SkyShroud
well, if changing battery doesn't fix the problem
means ur mb dying....got some part related to battery spoil
Koenig168
A possible workaround is to set the PC to sleep or hibernate instead of powering off.
hlots123
the battery contact, try bending up the metal contact in case it's contact issue...
peterchan75
Check the CMOS reset jumper(usually 2 pins), then refer to the motherboard manual and ensure that it's not on the clear CMOS position.
hafiz116
Sounds like there is a problem with the battery contact,.. is there any rust that can be cleaned up?
Also if its 8 years old its a granny board,... may want to consider upgrading :)
