Redmi Note 9
Apex01
Looks like ah neh shop, if got issues very hard to repair.
Yes **** shop. Shopee OnePhone is also **** shop. "M Zone" has collaboration with **** shop, they get phones from their next door.
For me and my frds we have more than 7 xiaomi phones, never spoil can use more than 2 years each.
bryant_16
Intending to get this or note 9 pro for my mother.
Is it good enough for daily use? Like YouTube phone calls etc?
Apex01
Note 9 pro with NFC and faster charging.
For normal use then Note 9 and Note 9S is fine.
All these can use 4G dual sim cards and one micro SD card.
ZrE0_Cha0s
Redmi Note 9 Pro.
ARS Digital World at S(218058)
Tel 62940786, 84411115
$296 Redmi Note 9 Pro (6GB RAM 128GB ROM). 1 yr shop warranty with receipt. Covers hardware repair. Tempered glass $5
seems like good price though.
Skyeagle
Hey guys, just to check with you all:
There is actually a plastic film screen protector already applied on the Redmi note 9 pro that can be peeled off right?
Devilsire
just interested to try Mi Mover since it's new to me. wondering what will get moved over (data & apps?).
i migrate using backup + restore before but that's for similar model. quite fuss free as almost all apps gets restored on new mobile. contacts, calendar can just sync back from google.
Works well, except for some apps where it'll prompt u failure to migrate and one need to manually install from playstore. Saves a lot time & hassles than installing each and every app
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
justln
Yup, it just works. SMS weren't transferred cause I didn't sign in to Xiaomi account, from 5A to Note 9S.
Tried the Wondershare, still need to connect USB to PC, enable developer settings, enable USB debugging, then install some Connector App and sign in to Xiaomi account. I just gave up half-way.
Skyeagle
By the way, check with you guys, when you switch the camera to macro mode, does your screen display turn green? As fill someone applied a green filter on it?
justln
Can paste glass protector over the plastic sheet protector?
Can, you just waste both the plastic and glass protector.
https://shopee.sg/product/162227755/3623009888
Bought SP from here, the black box dimensions slightly "shorter" so cover up a bit at the top and no hole for front camera. Also came with "filler oil", dunno for what. From the side can see a bit of the screen too, dunno why.
rrr2015
thanks! yeah those banking apps will fail to migrate
gregory_choo
are you using 3rd party app? or the default camera app that come with the phone?
JustForFun
Any lelong or cheapest sale, pm me.
Only keen in Xiaomi Note 9 pro (6GB+128).
Keen to get one soon.
Kitaro9202
One annoying issue I stream YouTube video my stream will keep buffering and play and buffering anyone facing this problem?
SoriyaGTR34
anyone else having poor battery life after updating to MIUI 11.0.5.0 ah?
Suddenly the SOT like sai. I used to be able to get 12 hours SOT. but after i update, drop to like 5-6 hours.
