OnePlus Nord
leowweiqi
waahhh... they keep say no impact, wait for update. So finally lazada shop said they will ask OP for direction on exchange/refund.
I said gib them 24 hrs before I escalate to Lazada to mediate.
By the way. Can you point me to a guide to reflash the original ROM? Might as well try it.
XDA have a guide on ROMs but it says can use the local update option in OTA screen.
I dunno if this is same as factory reset kind of thing which doesnt resolve this issue so far
You try local update using the full rom. If got error meant need use the msm tools methods.
https://forum.xda-developers.com/oneplus-8-pro/how-to/op8pro-unbrick-tool-to-restore-device-t4084953
leowweiqi
I believe you need someone with Nord to extract the persist IMG lo.
Code:
adb shell
su
dd if=/dev/block/bootdevice/by-name/persist of=/sdcard/persist.img
exit
divineone
I used MSM to roll back to 10.5.2. Din work either. :s13:
Anybody else got their Nords yet? Im more or less convinced theres a problem with my set.
is your Nord from official oneplus lazada store or other export set (like the 519 qoo10)?
xonix
Urgh :( Will you be getting something else?
I considered the Pixel 4a for a bit. The camera on 4a punches above its weight but Nord's cameras stack offers a bit more versatility, and with GCam it shouldn't be nearly on par with the 4a.
I would agree fully 100% except Gcam still doesn't support secondary lens on most devices unless you run it on custom roms.
