The Spectacles Thread. - Part 2
Velton
I read and read. More and more information. Haha..
So presbyopia.. go for office lens or progressives?
And better to add blue filter right?
Sent from Apollo 13 using GAGT
Maverick11
Might be fitting issue or maybe power. Did you went back to check again?
Already fedback, and the optician were saying he will get the lens consultant to come down and help with my case. But honestly, I thought distant vision should be the last thing that can go wrong, that’s why I am asking if anyone has met with such cases. One more thing, have anyone also heard/come across cases of “frame too big for progressive lens”?
GANGSTERKIA
Yes, a lot of individuals thinks that the bigger the frame the wider the field of view, but that is not true. Progressives comes with a fixed amount of clear view, thus anything out of the zone, it’s usually distorted. Bigger frame means when it comes to reading, the reading zone is all the way at the bottom too, meaning you need to chin up more to read resulting in neck pain.
Not sure if this is what you mean or if the frame is those gigantic ones that even the 80mm size lenses cnt even fit. That usually before you even make the glasses should warn you beforehand.
Maverick11
My frame is measured by 55.2 (width) by 38.6 (height), so I don’t think it’s oversized bah. I dun usually need to tilt my head much for reading as it’s a habit of mine that I tend not to read by moving it near my face. Rather frustrated not being able to see things from far to the extend that I might even go back to my old pair of glasses. Sigh.
Thanks for answering my questions, buddy. I just hope to arm myself with enough information so that I would not get ‘snooked’ the consultant.
GANGSTERKIA
Don’t worry. Just wait and see what happens during that day. Then discuss later :)
onizuka3
How bout I recommend you to other places instead which I know of? Which area do you prefer?
appreciate that, won't mind support u too
preferably somewhere in the East
btw, do u have any idea/experience whether after Blepharoplasty will eyesight?
GANGSTERKIA
Was it smth that affected you since young? Or only recently and then you want to get it done?
onizuka3
btw, mine is unilateral ptosis or rather one side is worse than the other
I went to look at my younger days photos, it seems minor
It seems to get worse when I started wearing contact 10 years ago
Now I look to get it done this Dec, do u have any Dr to recommend?
GANGSTERKIA
Oh yes, you can look for Dr Zena Lim, focal eye center. Do you have insurance to claim for private clinic?
Yeah, wearing contact lenses sometimes weaken The Eyelid muscles due to constant pulling when inserting the lenses.
onizuka3
why u recommend her over other Drs? based on your personal experience?
I'm checking on the insurance part ... saw that medisave can be utilised too...
Read that to claim both insurance or Medisaave will require ophthalmologic assessment ... probably will up the insurance before going for assessment
any idea will your degree change after the surgery?
onizuka3
Gangsterkia ... any ideas?
GANGSTERKIA
Oh, i have many positive feedbacks from this doctor.
Also i know the staff there so i feel they are reasonably professional.
Yes, possible that prescription might change after the surgery, usually give it about 2-3months to settle.
Whizdom
Rayban shop, check out their main store e.g. Vivo,313
im looking at those optician shops kind. Try on frame and also make the lense. If rayban shop can't do the frame? Cos I doubt frame alone if buy separately cant claim from my company
Sent from Samsung SM-N975F using GAGT
onizuka3
Any ideas what’s the price range like for the whole operation? Maybe u can Pm me
Should I get the specs now?
Btw, who do u recommend for silhouette frames?
