tohchr
- Oct 7, 2004
Once u set it up, it will auto registered inside support app.and btw how do you guys register for warranty? is the telco receipt required?
i heard from a telco staff; if you side-load GMS, it voids they warranty
anybody here using the phone for what it should be? aka HMS?
thanks for the info!
btw how did you guys port your whatsapp history into your P40?
any advice? coming from iphone
No it doesn't void any warranty.i heard from a telco staff; if you side-load GMS, it voids they warranty
Sideload if you wanna use gpay.There isn’t a camera in the world that can, or will ever make up for the loss of GMS, but that’s just me. I use Google Pay for everything and losing that is an instant dealbreaker.
So far there are 2 proven methods to backup and restore WhatsApp msgs but its only from android to android -i actually need my whatsapp history because of work..
wondering if Dr Fone would work with Huawei... it’s still Android at the end of the day..
Wait for mate 40 series to be released in Singapore if you're not in a rush, P40 pro + price will drop once mate series is out.I m currently using Mate 20 Pro (Bought it on launch day)
Is it better to wait for Mate 40 Pro or select Mi 10 Ultra or P40 Pro Plus.
Any suggestions?
Any suggestions?
I helped you to check on huawei app gallery but its not available yet -
Guess you need do try the other methods that I've suggested if you really want to use a p40 series phone.
Sent from somewhere out there using GAGT
If relied on something until cannot do apart, then next time difficult to try other brands. I'm using China 20x without google for almost 2 years, no issue. Only thing that I cannot do apart is native call recordings in mobile phones. Cos my coy a lot of prata king, call recording saved me numerous times. So, I would get China version Huawei or Asus rog 3 which had call recordings natively in build.was looking at the youtube video again..
i guess even though we can get it to work eventually, getting GMS on the phone requires so much work
best to just accept HMS as it is, and use it accordingly
