Redmi 9 series
Angtehkor
That is also a much more expensive phone as compared to redmi 9?
I still considering whether to sell as this redmi 9A have 1000 charge cycles and also each day I use between 15% to less than 25% of battery. If I sell my redmi 9A with over 980-990 charge cycles left I will be very lugi.
Angtehkor
Ok lah now 89% battery left with 2 hours 53 minutes sot. Fully charged and plug out this morning at 7.38am
Angtehkor
Auto brightness for this phone really drain battery really fast as the brightness level is a lot brighter than usual.
ZrE0_Cha0s
REDMI 9I WILL LAUNCH ON SEPTEMBER 15 IN INDIA
Already from the name, it is clear that the new product will become part of the Redmi 9 family, where, in addition to the basic version, there are already Redmi 9C and Redmi 9A, as well as Redmi 9 Prime in the Indian market. It is logical to assume that this will be a light version of Redmi 9, but there is no understanding what kind of simplifications will occur.
Teasers announcing the Redmi 9i only give an understanding that the smartphone will receive a display with a drop-cutout for the front module and a 4 GB of RAM. The landing page of the model also promises that it will offer a large battery, decent internal storage, best cameras in its class, and good gaming capabilities. The Redmi 9i will ship with MIUI 12 and it will almost certainly come with a MediaTek chip.
sauce: https://www.gizchina.com/2020/09/09/redmi-9i-will-launch-on-september-15-in-india/
more rebrands :s22:
matrix05
Redmi9, got sellers drop 4/64 to 179sgd. This model and poccoX going to squeeze the note9 market hard.
Angtehkor
Really beh tahan this phone. I purposely drain this phone to 2% and charge it. Guess what, it took 2 hours 57 minutes to fully charged it. The standby very lousy drain a lot of battery.
Angtehkor
I might throw away this phone and get myself a Samsung galaxy M51 with 7000mah battery and Snapdragon chipset which many bros here like this Snapdragon as they say it the best chipset and this Samsung M51 phone is amoled display with save battery on dark mode/themes/background. The current phone I use take very long to charge fully, even 85% took 1 hour to charge and mediatak chipset super lousy standby drain battery like water, if you don't use the phone the sot not so good. Yesterday I battery is 2% after 3-4 days never charge and it take nearly 3 hours to full charged as a lot of time wasted. Although the redmi 9A claimed to have 1000 full charge cycle but super slow charging and standby drain like water really turn me off.
ahwei91
come, throw it to me...
davidwong
Bro did you take pricing into consideration if you can afford it better phone why did you get this in the 1st place and already knowing it’s a basic phone and you are looking at amoled and your SD 730 which cost 323? Which is in some variant of Redmi 9 is 2x the pricing
For a basic phone that cost between 129 -179 (depending on which variant you gotten) you will be looking at SD 435 looking at HD 720p and 2-3gb ram and 16-32 rom and may or may not be even micro USB charging with a 10 w charger.
So is either you are trying to cheap out and then regret and realise you should have paid more, which I will say too bad you should have done your research or don’t be a cheapo
Or you are just a ****ing idiotic samsung fan boy. Or other motives influence by samsung (my assumption maybe wrong so you can’t POFMA)
If so you are also ****ing idiot for 323 range there are better choices than m51 example pocco series or the K30 series or the realme series or the oppo series all about the same pricing range and beat the crap out of samsung. Just like how we bro in here is beating the crap out of your idiotic BS.
twisti
ATK is one of the certified siaolangs in the forum. He is only interested in phones with massive battery. Poco X3, K30, etc not suitable as battery is too small. To him, battery life is more important than performance.
Angtehkor
My this redmi 9A very drain battery one. I put my giga SIM card in my spare Samsung m30s phone dBm 50 plus to 70 plus max is low 80dbm. But giga SIM card inside redmi 9A 90plus to 100 plus dBm
jazz2005
What about Redmi 9C? Is it better than Redmi 9A? I'm planning to get either Realme C11 or Redmi 9C for my mom. Any recommendations for bros here?
RLWZ21
well 9c is definitely better but its just slightly, u can consider note 9 for your mum though. better screen for her to watch her favourite show on the phone.
or maybe u can stated your budget and other requirement so that maybe more bros here can give even better recomendation.
jazz2005
Thanks for your reply. I'll probably get her the 9C. She just need the phone to call me to pick her up from the CC which she goes to once a week, and also the safe entry app. She has been using a iPhone 6S that I had passed down to her but the screen has some black patches recently (must have knock the screen against some hard objects), and I guess getting a lie soec phone would be better than replacing the screen on the 6S
chooyoshi
Should consider upping a little higher for the redmi 9, would be more worth it long term
