Redmi Note 9
Nuclear Boy
I just plugged in my 9Pro to charge for the 2nd time since last week. I noticed now it is only charging at 20W instead of the original 30W from the first time. I have a power meter so I plugged in to see how much it draws while charging, which I forgot to do in the first time round. I did see it draw 6A on the 1st time though, from a battery app on phone. Now it would just go around ~3.5-4A (18-20W).
I updated MIUI to 11.0.5.0 from stock 11.0.4.0 a short while after 1st charge, so I'm not sure if it's a bug or an actual issue. I'm using the original charger and cable in the box. Battery temp is ~40C in both cases.
Anyone notice if your phone charging slower? If you have a power meter or even a battery app like AccuBattery or Ampere, can let me know what kind of current does the battery charge at up till around 50% from some lower amt?
EDIT: Just finished a full charge (11-100%), 1h20m. Is this the normal rate you guys get?
Channelson
if you add usb meter, the charging current will drop due to meter resistance.
Total time with meter is longer than without
hkchew03
3.5-4A might not be 18-20W. U need to see the voltage. Most quick charge ain't done on 5V. If 9V on 4A is 36W already.
Nuclear Boy
I'm using something like a kill-a-watt, not an in-line USB meter. Is a whole 3-pin socket which I can plug anything into, and it reads in raw Watts. I know QC is definitely not on 5V, but whatever voltage and current shown by app checks out with what is shown on the power meter (Power = Volt x Current)
EveMuffins
My request for refund for 9 pro due to scratch at the glass back and stuck on/off button is approved. Money refunded into my credit card already. :)
addict951
High Honorary Member
Ask y’all hor, N9P has this little light on the top that blinks slowly - can it be disabled?
ivxrzexc
Switched from Redmi 4x to Note 9S for about a week, experience is not as smooth as I thought. Some lags here and there, camera so-so (even photos taken in daylight have a lot of noise), and only 1 speaker so videos and music not as shiok. Will go back to 4x and keep as spare.
human_shieldz
If you are coming from Redmi 4X, how is Note 9S not a significant upgrade??!! :eek:
Camera is not amazing i agree but it's 200-300+, surely you can't expect it to be flagship level and also it must be a lot better than Redmi 4X.
Keeping 9S as spare and use 4x is a really strange decision:s22: It is even snappier than my Galaxy S7 Edge.
gregory_choo
redmi 4x has only 1 speaker too.
Nuclear Boy
Anyone tried custom ROM from XDA? Note 9 pro sg version is call note 9 pro or 9 pro max in XDA? Thanks
Indian N9Pro = Global 9S (codename Curtana)
Global N9Pro is codenamed Joyeuse
N9 Pro Max (seems universal) is codenamed Excalibur
Just take note of the Joyeuse tag if you're looking for ROMs there. I also found a Telegram channel full of updates and ROMs etc just for Joyeuse. Let me know if you want to take a look, can PM you the link.
philips110104
Thank you for the details info, Xiaomi model is really confusing. Appreciate you cnn pm me the telegram channel name pls. TYVM.
