compro_1975
- Jul 5, 2004
any place to spray the whole car? i no need to crazy fancy one... just a normal car need to restore the paint and also do up those dents....
i was told a sticker at the driver sun shade flap showed the car travelled 2000km after owner has sent for servicing, should be able to run for another 1-2000 km before changing?
How does that sticker work? Does it show the next mileage point for oil servicing? If thats the case then it seems fine. then again, I changed mine within a month of purchase even though i could go another 5 to 6k
any reliable workshop in JB to recommend? Easy to find? Been 20 years since i last drove into JB...Previously bought a 10yo stream. I've changed eo, Atf, spark plug, brake pad, clean tb, rear bushing, engine gasket, front link for a peace of mind. Gonna change my radiator, ICE, shock when jb open up..
Too bad have to change my cooling coil recently. Otherwise will go over to jb instead.
Similar to you I bought a renewed Stream and replaced these including front shocks. If I may ask where would u recommend for ICE in JB?
there's couple of ws recommended in this thread. carclick, lten pro. u can find their address online..
ICE can look for sheng auto. can find them via fb.
CarClick good at troubleshooting. Feel Sheng Auto overrated though i understand they are quite popular.
May i know what is ICE?There are a few along the main road leads to KSL. You wana try just make sure do your homework and get a few quotes.
Over here, many avoid this area.
Sheng Auto overrated? You used them before? I did used them a few times for other stuffs than ICE.
The workshop i goes for a/c servining;- Yigo Air-conditioning. Find them on FB.
They also do spray painting and dents.
Got them fixed up the dent weeks ago.
many thanks, shall check it out.
anyone else got good place to spray the whole car and remove dents?
u ok to leave car there for a few days to a week??
