Singtel 5G is here!
mistersoh
Don't this also mean our data used up faster? Hahaha
Posted from PCWX using ALP-L29
renfred89
4G and 5G difference is the data speed, not data chunk.
If you need to utilise a fixed amount of data per action, then 5G delivers it faster than 4G.
5G will never use up more data in that sense, unless the faster data delivery makes you surf more, then its your own responsibility already. :p
mistersoh
:p
I see. Thank you! :)
Norman Chan
So anyone try out the Singtel 5G download speed of their 5G enable mobile phone ?
vaxvms
actually quite subjective esp those running in the background
last time 3g era dun use much data
magix
856Mbps at Mount Faber
Wow.. This is good..
Highest 4G speed i get from iphone
Gmailer
chaiscool
Nice, just ordered iPhone 12 pro max with 28Ghz mmwave!
https://www.apple.com/iphone/cellular/?irgwc=1&aosid=p239&cid=aos-sg-aff-ir&irchannel=13656&irpid=10078&clickid=yxTyQ51JNxyLTX4wUx0Mo3QnUkEUYTTZqSbU3s0&ircid=7641#iphone-12-pro-max
YouTube on pro max gonna load 1ms faster.
