(GPGT)Espresso machine hoot
Hello
Thanks for the tip, will consider getting a 'branded' basket to try. My basket seems to top out at 15.5g so I don't think I can do 18g
Possible to share the Amazon US link if you still have?
Just search IMS
Sent from Tehhan's iPhone using GAGT
ksw101
Recommendations for Saeco descaling and greasing brew group
Hello,
I have Saeco Aulika(machine only) from my oversea friend. Does anyone knows or recommended products for descaling and greasing brew group? I tried to search online shops, but can't find any...
Thanks.
ksapple
Cleansui filter?
Mine is using bwt, something like this
idjekyll
Does anyone here use the Eureka Mignon series grinders for single dosing? Any feedback on it?
purpleberry
Hello,
Thanks.
I think Tangs or Taka sell Saeco. Maybe you can ask their sales staff?
patryn33
Is lelit 57mm or 58mm??
Anyone know the price for
LELIT Anita PL042TEMD
I am think of upgrading from my dedica w silvia steamwand
Specs see here
https://espresso.lelit.com/product/4
https://sg.carousell.com/p/lelit-anita-pl42em-combined-espresso-machine-official-authorised-singapore-distributor-118328152/
Aryan13579
Hi all, currently selling breville infuser + sette 30 on carousell (@aryanjain). Do check it out if interested!
KoChi
anybody using breville barista pro? I'm new to this espresso thing and have been always on Nespresso capsule for donkey years.
is this machine good for a start?
Lazy_Tiger
Good luck with your over technology filter.
This filter remineralise with magnesium, making it even harder than tap water.
Magnesium is part of limescale formation.
limescale formation is not so simple as just having magnesium ions......
if you look at the bwt system it is also designed to reduce limescale formation despite adding magnesium for taste..
best to look at the data sheet or test the tds yourself with local supplies to see if it meets the machine's requirements.
compuser
wahjohreno
I'm deciding between Niche Zero or this.
Sent from Google PIXEL 4A using GAGT
I had the Mignon, gave it away after I got the Zero.
If you're a single dose person, there's no comparison. The workflow is just not in the same league.
SNAG
Tempted to switch from my Sette 270Wi to this.. doing more single dosing nowadays. Any quirks to the machine so far?
