SoundBar or Bookshelf Speaker
FreeRoon
Hi,
I am doing a dual monitor setup with a new computer. (XiaoMi 34 Inch curved monitor)
A soundbar or bookshelf speaker better for watching show/movies?
Budget is around $300-$400
Thanks in Advance
ragnarok95
Senior Moderator
Senior Moderator
I would prefer a sound bar like creative blaster max katana.
Hafi
got space put bookshelf or even a 5.1, no space then get a soundbar.
wwenze
Guess which speaker was sold away
Hint: The soundbar
Hi,
Thanks in Advance
This one must choose a Bookshelf that has a clearer vocal sound signature.
Soundbar will need extra sub woofer.
AS1
Hi,
Thanks in Advance
I suggest you go Harvey Norman or Challenger to test the soundbars. The waveform not for everyone.
Personally I'm using a $30+ creative d something something soundbar because I like that it has very strong mids. Reminds me of last time ATP3.
FreeRoon
Hint: The soundbar
the soundbar is so bad? hahaha
bookshelf speaker has to be pointing towards the user for better performance right? i scared with 2 monitors the distance might be a bit far hahahah
wwenze
Soundbar also need to point towards the user for better performance
Speakers also need to be apart for better performance. But soundbar stuck in center
batniss
If someone have katana (or any soundbar similar can share)
1. Does it need an additional power point to power the device?
2. It works with audio jack ?
3. When turn on does it makes sound?
4. When it detects no connection does it make sound, standby or turn off itself?
5. Does it turn itself on when it detects a connection?
Reason i ask because i am used to monitor having speakers now my xm 34" no speakers and i test those portable speakers... Either during power on it is too loud or during no connection(eg i off my monitor) it makes alot of sound.
Gixxerfied
Not bookshelf but i love my swan m50w..
Can really hear the diff between this and the aego m i was previously using..
Gixxerfied
This pic alone can ans the first 3 question for katana..:s13::s13:
Gixxerfied
probably first 2.
3rd, no indication will there be a sound (i do not want sound). LED is fine.
Yup first 2...
I think you can find video review and usually will know if it makes any sound powering up(I doubt so)..
If it's being market for use with tv like all soundbars out there,
Q4: should go into standby without sound
Q5: yes if it's standby mode
That's how my ex sony sb and current sonos beam behaves.
batniss
Yup first 2...
maybe i should just lower my budget to the stage air :s13:
