Xiaomi Mi10T Pro
xtractor
Anyone knows when this phone will be available in singapore?
How much will it be?
Getting new phone dono to get this Xiaomi Mi10T Pro or Samsung S20 ultra
If this is cheaper I may buy this phone
aucheukyan
get the s10 lite if you still can, if cannot get the s20 non ultra or f2 pro
Sent from null using GAGT
xtractor
i am referring to S20 FE not plus .. FE is snapdragon .. S20 Plus is exynos
yes i know s20 FE is selling @ $1098 even though it came with qualcomm snapdragon chipset it is Super AMOLED with resolution of 1080 x 2400
and s20 plus which is selling @ $899 came with Exynos chipset Dynamic Amoled 2X capacitive with resolution 1440 x 3200
i prefer better picture and i can lived with lesser battery hours that i can just use powerbank to charge it
just because of the chipset it is expensive thats all
check out the spec comparison
https://www.gsmarena.com/compare.php3?idPhone1=10377&idPhone2=10080
fireantz
kinda outdated with phone tech. what should the screen be if LCD is not good?
deckcard
Bro, you won't see much difference with the 1440p screen. The screen size is not big enough to make it a big difference. Besides, Samsung runs default at 1080p unless you specifically change it which not many do.
I haven't bought any Samsung phones after s7 days becos exynos chips are just inferior compared to snapdragon. Now with the s20 FE, I may actually give them another try.
Jun Jun
Anyone with blurry camera issue, where. Camera cant focus? I have the issue on the latest firmware 12.1
Jun Jun
Btw, i saw 2 iphone 12 have the tracetogether app issue that cant scan, so this issue is not exclusive to xiaomi only. It is tracetogether app having bugs.
