Downsizing PCs
FinalTidus
My downsizing needs are actually quite similar to TS but the main difference is that I still actively game on triple AAA games and want the flexibility to still upgrade components when the need arises. Wanted to create a thread but it is what it is.
My rig==> Casing is Corsair 730T which my friends have all said its overkill for my needs and components.
My friends have said that having a smaller case will actually help in airflow as although my case is big and airy, it actually doesn't have efficient airflow. Having a smaller case would help in better movement of airflow.
Since then I have been wanted to shift all my components to a smaller casing. NZXT has been always the talking point by my friends so recently I have been looking at NZXT H710i for sometime.
Not sure if anyone can advise too. Requirement is must fit all my components from my current rig. :)
You can consider using a Cube Casing.
wwenze
Think with your atx mobo, not much smaller..
mATX is best since it is just slightly bigger than mITX but that extra size is for more expansion slots which come in really useful
But manufacturers don't like small mATX cases sigh. Partly due to the additional depth allowed for mATX, but that is not really an issue when many mITX cases are long to accommodate graphics cards. Plus the area above the mobo not blocked by the card can be used for HDD. There needs to be more sub-20L mATX cases.
Gixxerfied
I went from matx(been on it since the start) and now mitx...Good enough for my requirements with the nr200 case..
NightRaven49
most matx cases are above 20l, and those that arent generally have gpu/psu restrictions to achieve sub-20l. i think 25l is the sweet spot, with enough space for airflow, part clearance etc while still being not too big, and there ur options are aplenty.
Gymrat76
Actually for these small setups are they sufficiently powerful to connect to a 34” monitor and to run at 3440x1440 resolution (videos etc.)
