Blueberrytea
- Dec 10, 2017
Yes it's 392.
Thanks alot @dantysmile
Yes it's 392.
ok time for me to jump from ios to android, just purchased from google store, cant wait for courts
Does the pixel 4A at $499 have 1 year warranty?
This 4a has 90hz refresh rate?
how do you users of caseology case users (vault) or otterbox users (commuter) find them?
do they get in the way for gesture swiping from the edge because of the more prominent rim around the screen?
Vault has been really nice so far. No issues with gestures perosnally. I would recommend anyone looking for a quality case to at least check out the vault in hand.
Anybody facing issues with notification sounds after turning off Do Not Disturb?
I normally turn on DND before going to bed, when in the morning I turn off DND but notice I don't get any sounds for my notifications. Sliding up and down the volume doesn't help. Only a restart helps.
No issue but I use silent hours...
How to set silent hours bro?
Settings > sounds > do not disturb
It's actually a DND scheduling..
There are controls for the exceptions, like starred contacts can still ring when they call.
I am using that. But sometimes notification still ring when the schedule activates![]()
After the scheduled hours, notification sounds are ok?
