LaksaTitan
- Apr 7, 2013
Thanks!Jamco, eyewear optics, kj optometrist, Mr eyewear
Are options that you can look at.
Sent from OnePlus 7 Pro using GAGT
Just curious, does the high vision long life coating from Hoya stand up to weekly washing with less-harsh hand soap, e.g. those Kirei Kirei? Or will weekly washing like this, hasten the deterioration of the coating?
I brought a spec oversea and need to do some adjustment on the frame.
Can I just bring to any spec shop to ask them help me to adjust, FOC?
As Long as you understand any damage that accidentally happens during the adjustment is subjected to your own risk. Shops should be agreeable.
Elma ultrasonic cleaner where to buy? I know optical shops using this but can't find anyone selling. Also online is mostly 120v version.
I don't trust a $100 cleaner to not ruin my 1k+ glasses. Elma is German and used by opticians.Taobao alot cheap n good. Suitable for sg too
I found somewhere selling but price is about 1k. Do shops use the heater or just normal room temp water when cleaning?Can’t help you with that, but take note, don’t soak the glasses in ultrasonic for too Long, it will cause the coating of the lenses to peel over extended wash.
Edit: if your glasses is old, the paint/coating of the frame will flake because of the ultrasonic vibration. Be careful!
Realised my lens coating is starting to peel out from the ends after about 2 years of wearing.
Wonder if I choose to buy more expensive lens will it be the same?
Whats the general price range for either a transition-style zeiss digital lens or the hoya sync 3? I need the added power for my reading distance, even though I'm only in my late 20s
Made a new pair recently but keep having glare issues and I checked with an eye doctor who said there's nothing wrong with my eyes, so I don't know what type of lenses might be good for it
Glare is generally occurring when I look at bright surfaces, electronic devices and lights. It's like ,the 'glare' portion of this photo.
It usually happens more in the day time, but night time it does especially when looking at lights , or like white fonts and stuff on my phone.
I'm using full frame plastic frames, which are matte in nature, from my understanding.
I bought my frames from a certain shop that's pretty well known previously, but looking to try other shops.
Have you tried with your old glasses to see if the issue persists?
