iPhone 12 Series
WestGuy
Will Singtel change the combo price plan after rolling out 5G plans?
Wow increased price by $10 already.
I recontracted to Combo 12 last month.
Old Combo 12 at $239.90
36GB of 4G data(because of free DataX3 for 2 years)
New Combo 12 at $249.90
22GB of 5G data
Which would you all prefer?
argentinafa
22GB of 5G data
1st one seems like a better deal for you bro. At least if I were you I'd choose a).
14gb of difference in data is alot. Actually 4g is kinda fast already for outside mobile phone surfing usage.
ryan_khoo
Is it wasted if buy 5G iPhone but subscribe to 4G ?
Then again, is it a waste to pay extra for half baked 5G line?
Thanks
i.Singaporean
Anybody already decided to get the Mini over 12 without playing with demo set ? Feels like need to go down and touch touch see see before deciding.
meee
My iPhone X still working fine but hand itchy never change phone for 3 years so buying 12 mini(cheapest 12 model) to tide me over until next year when they introduce 120Hz :s12:
Snoweagle
For 5G to fully mature here may take more than a year, maybe even longer.
ryan_khoo
In terms of camera capabilities, what’s the difference between Pro & Pro Max ? Only 4x optical zoom vs 5x optical zoom ?
Is the Pro Max really 5x optical zoom bcos the actual word they used are “5x optical zoom range”
Thanks
Snoweagle
Thanks
Pro Max is using sensor shift for stabilisation, the Pro is using regular OIS.
i.Singaporean
Thanks
- 52mm to 65mm for Telephoto lens
- Sensor on the wide camera on Pro Max is also 47% larger
- Sensor-shift OIS instead of normal OIS
*adiBOY
Thanks
Apple marketing terms. They calculate from ultra wide to tele. So 13mm to 52mm for the Pro (4x).13mm to 65mm for the Pro Max (5x).
The wide sensor on the Pro Max is bigger which allows more light to enter resulting in better photos. Also, there is sensor shift stabilization on the Pro Max’s wide camera.
ecneret_eel
apple really wants you to buy its biggest phone, can’t even put the same sensors into 12P
*adiBOY
It’s only for the Pro users tbh. Regular consumers wouldn’t notice all these differences and differences in the photos taken.
ryan_khoo
alamak this is a gimmick, no wonder they used the word “range” ... so the real optical zoom is only 52/28 ~ 1.85x for Pro and 65/28 ~ 2.35x for Pro Max
so can get better bokeh lah ?
So good for the shaky hands apek like me lah ... 👌🏽
*adiBOY
It’s 2x and 2.5x technically. The wide lens is 26mm.
Not better bokeh but better overall photos especially in night scene as more light can enter.
